Coordinate transformations Spherical to Cartesian
Transforming a vector from spherical to Cartesian coordinates requires knowledge of the angles theta and phi, which are derived from the Cartesian coordinates (x, y, z). The original poster initially struggled to find these angles without knowing the endpoint of the vector. However, it was clarified that the Cartesian coordinates can indeed be used to calculate theta and phi. This realization helped the poster understand the relationship between the spherical and Cartesian systems. The discussion emphasizes the importance of recognizing how coordinate systems relate to one another in vector transformations.
gaganaut
Hi,
I would like to transform a vector from Spherical to cartesian coordinate system. But the question is probably not that straight forward. :(
I have a vector say E = E_r~\hat{r}+E_{\theta}~\hat{\theta}+E_{\phi}~\hat{\phi}.
But I know only the cartesian coordinate from where it starts, say (x,y,z) and I do not know where it ends. So I am unable to find angles \theta and \phi for computing the transformation matrix R that transforms the vector E to cartesian system. This R is the usual matrix with sines and cosines of \theta and \phi and can be seen here.
http://en.wikipedia.org/wiki/Vector_fields_in_cylindrical_and_spherical_coordinates
So how do I go about it. Is there even a way to do this. Once again this is not a homework question and is for a small project that I am doing. There aren't any homeworks at this time of the year. :)
Appreciate any form of help.
Kedar
Mathematics news on Phys.org
What do you mean, you don't know where it ends?
Isn't the (r, theta, phi) system relative to (x, y, z)?
May be I am missing something very simple here. But I do not know the (r,~\theta,~\phi) as well. I did try to do it that way though to start with.
All I know is the magnitudes in the \hat{r},~\hat{\theta} and \hat{\phi} directions and the starting point. And nothing else.
Can the (r,~\theta,~\phi) be found out from the magnitudes in the \hat{r},~\hat{\theta} and \hat{\phi} (E_r,~E_{\theta},~E_{\phi} as above)?
It can be really simple. But I cannot just think about it right.
Yes, you might be missing something or I might.
But aren't the coordinate values simply the coefficients of the unit vectors?
Like, in a Cartesian system you can write either (3, 0, -2) for the coordinates of a point, or you can describe it by a vector 3 \hat x + 0 \hat y - 2 \hat z.
When writing down a tuplet of numbers like (3, 0, -2), we are implicitly assuming that we have these three basis vectors \hat x, \hat y, \hat z and we are using them to fix our point.
Thanks Compuchip. I got your point. So stupid of me. The (x,y,z) can be used to find theta, phi. My bad.
You're welcome. We all get confused sometimes.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
