Determining Maximum Lamp Mass for Coplanar Force System
  • Thread starter Thread starter Robb
    Force Systems
The discussion focuses on determining the maximum mass of a lamp supported by a cord system without exceeding a tension of 350 N in any single cord. The equations of static equilibrium are applied to analyze the forces acting on the system, leading to expressions for the tensions in the cords in terms of the lamp's weight (W). Participants clarify the relationships between the forces and correct earlier miscalculations, ultimately concluding that the maximum weight W is 175 N, which corresponds to a mass of approximately 17.8 kg. The importance of accurately identifying which cord experiences the maximum tension is emphasized throughout the problem-solving process. The thread concludes with confirmation of the correct weight and mass calculations.
Robb
Determine the maximum mass of the lamp that the cord system can support so that no single cord develops a tension exceeding 350 N
F(x)=0; F(ED)cos30 - F(CD)= 0
F(y)=0; F(ED)sin30 - W
F(ED)= 2W
F(CD)= 1.73205W
F(X)=0; 1.73205W - F(AC)(3/5) - F(CD)cos45 = 0
F(y)=0; F(AC)(4/5) - F(BC)sin45 = 0
F(AC)= F(BC).88388
This is where I start getting confused. With all the substitutions.
This is incorrect. Check your FBD and make sure you're writing out your equation with the correct subscripts.
From the lower fbd:
F(x)= 0; 1.73205W - F(AC)(3/5) - F(BC)cos45
Robb said:
From the lower fbd:
Alright, so substitute in for F(AC) in this equation. Use this to write F(BC) in terms of W. Afterwards you can then write F(AC) in terms of W. You will then have expressions for all the forces of tension in the ropes in terms of W. Comparing all of these you should be able to determine which rope develops the maximum tension in this system.
Also, as a quick alternative to going through all the math: Examine each FBD carefully. Assuming static equilibrium of the ring at point D, it can be said that F(DE) must be larger in magnitude than F(CD) since only one component of F(DE) balances the force F(CD). A slightly more careful consideration of how this strategy applies to the FBD of point C should lead you to find which rope is under the maximum tension. As you can see, most of the trouble in this problem is finding that particular rope.
So, F(AC) = .88388F(BC)
1.73205W - F(BC).53033 - F(BC).7071 = 0
-1.23743F(BC) + 1.73205W
F(BC) = 1.39971W
F(AC) = 1.23718W
W = 150
The answer is 17.8? Not sure how to get there.
I like the insight. Now that you mention it it looks obvious.
F(BC) = 1.39971W
F(AC) = 1.23718W
W = 150
See edit to W.
Ok. I got it. Sorry. Thanks for your help!
Robb said:
W = 150
No problem. Just one last thing.
Not sure if your edit on your post for the value of W worked. Just to clarify it should be 175 N. Although I will assume that you must have gotten that result if you calculated 17.8 kg as the mass.
