Copper Electroplating, cell voltage = 0V?
In a copper electroplating scenario with both electrodes made of copper in a CuSO4 solution, the cell voltage would indeed be 0V due to the equal reduction and oxidation potentials. The concentration of CuSO4 does not significantly affect the Ecell when the electrodes are close together, as the activity can be approximated by the ion concentration. In stable electroplating baths, determining Ecell deviation from the standard hydrogen electrode (SHE) can be complex, especially at varying concentrations like 0.1M or 5M CuSO4. Additionally, while SHE measurements are typically conducted on platinum electrodes, there are methods to analyze overpotentials for different electrode materials, though resources may vary. Ultimately, in electroplating, the applied voltage is more critical than the inherent cell voltage.
tinska.h
Please post this type of questions in the HW section using the template.
Hello everybody,
this is probably a very novice question, but imagine anode and cathode, both made from copper immersed in CuSO4 aqueous solution (1M at standard temp and pressure + assuming electrodes are very near each other -> minimizing diffusion/migration resistance) and:
Cu(2+) + 2e- -> Cu(s) = 0.337V (SHE)
and
Cu(s) <- Cu(2+) + 2e- = -0.337V (SHE)
In this scenario would the cell voltage be 0V? In literature and articles Ecell is usually defined as Ecell = Eox + Ered.
If this is correct, does the CuSO4 molar concentration affect Ecell if electrodes are very near each other? How does one determine activity coefficient in Nernst equation?
Thanks!
Yes, E cell would be 0. Activity - as a first approximation - equals ion concentration. Google "concentration cell".
Thanks for the help.
In concentration cell, it would need to have concentration gradient. But what about in electroplating bath, where concentration is quite stable across the bath? How do I determine Ecell deviation from SHE for example in 0.1M CuSO4 or 5M CuSO4?
Also, since SHEs are performed on Platinum (or platinized?) electrode, are there analytical methods for determining overpotentials for various different electrode materials? Or are there good lists available? For example does oxygen evolution differ from SHE on copper electrodes?
Thanks!
In electroplating you force voltage upon the cell, so the voltage of the cell itself doesn't matter (much).
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
