What are the Corresponding Reaction Forces in a Suspended Bowling Ball System?
In summary, the reaction force to the 65 N force of tension in the rope is equal in magnitude but opposite in direction. It is exerted onto the bowling ball by the rope.
physicsnobrain
123
A bowling ball is suspended from a ceiling hook using a thin piece of rope. If the rope is
exerting a 65 N force upward on the ball, describe the corresponding reaction force in
terms of:
(a) its magnitude
(b) its direction
(c) on what object it is exerted
(d) by which object it is exerted
A) The magnitude corresponds to the force of tension in the rope, and the ball isn't moving anywhere.
B) direction corresponds to the force of gravity because this is where the ball will go if it is released from the rope.
C) Force is exerted on the rope
D) Force is exerted by bowling ball because of F = ma
Am I right?
thanks
Or is A) the normal force
Or it is
A) The magnitude is upwards to the cieling hook
B) The direction of the bowling ball is south
C) The force is exerted onto the hook
D) The force is exerted by the bowling ball
physicsnobrain said:
Or it is
D) is certainly correct.
I'm not quite sure that C) is right. It's true the hook feels a force, but the rope is what pulls down on the hook. What pulls on the rope? (Hint: reaction forces occur between two objects only. So if object X exerts a force on Y, the reaction force must be exerted by Y onto X)
For B), I would simply say down because the problem doesn't mention north, south, east, or west. You certainly have the right idea, though. Why is it that the answer to B) is down, though? Can you perhaps think of a physical law that might explain why that's true?
And as for A), magnitude refers to a number. So, for instance, the magnitude of the force the rope is exerting on the ball is 65 N. So, do you know what the magnitude of the force the rope is exerting on the ball is?
I think that that C and D are now:
C) The force is exerted onto the bowling ball
D) The force is exerted by the rope
You said the magnitude of the force the rope is exerting on the ball is 65N, then you asked what is the magnitude of the force the rope is exerting on the ball.
What?
What?
You're right, I'm sorry, that was a typo. You know the magnitude of the force the rope exerts on the ball is 65 N. What is the magnitude of the force the ball exerts on the rope?
also 65N
also 65N
Exactly! That comes from Newton's Third Law of Motion, which says that the force that X exerts on Y is equal and magnitude and opposite in direction of the force Y exerts on X. So that's A), now what about B)?
The direction is then upwards, in the same direction as the tension force.
Not quite. The reaction force is equal in magnitude, but opposite in direction. So if the rope (the tension force) is pulling the ball up, then the ball should be pulling the rope in which direction?
downward
And C is the force is exerted onto the bowling ball
and D it is exerted by the rope
1. What are corresponding reaction forces?
Corresponding reaction forces are equal and opposite forces that are exerted on an object in response to an applied force. They follow Newton's Third Law of Motion, which states that for every action, there is an equal and opposite reaction.
2. How do corresponding reaction forces affect an object?
Corresponding reaction forces play a crucial role in maintaining the stability and equilibrium of an object. They ensure that the object does not move or accelerate in a particular direction when a force is applied to it.
3. What types of forces can generate corresponding reaction forces?
Any type of force, such as gravitational, electromagnetic, or mechanical, can generate corresponding reaction forces. These forces can act on different parts of an object simultaneously, resulting in multiple corresponding reaction forces.
4. How are corresponding reaction forces related to free body diagrams?
In free body diagrams, corresponding reaction forces are represented by arrows pointing in the opposite direction of the applied force. This helps to visualize the different forces acting on an object and their corresponding reactions.
5. Can corresponding reaction forces cancel each other out?
No, corresponding reaction forces cannot cancel each other out. They are equal in magnitude but act in opposite directions, so they do not cancel each other out. Instead, they work together to maintain the equilibrium of an object.
