TrickyDicky said:
Might perfectly be the case, I'm not particularly smart. I'll try harder.
But then, how exactly is expansion ascertained? I thought expansion had something to do with motion. But if motion of cosmic objects is referred to overall expansion, what do we refer overall expansion to? The CMB? And I'm still not sure if you are saying that the CMB is a global or just a local frame?, if I understand you correctly then by the overall expansion link to the CMB, it must be a global frame. I've seen some pictures of the observable universe as a sphere with us in the center and the CMB as the boundary of the sphere, with the microwave radiation reaching us isotropically from every point of the boundary, this would be compatible with the CMB as global frame and with the coordinate system defined respect to the expansion. The problem with this picture and your corrected coordinate system is that in itself it is static, and if you don't use the objects in the universe to define the expansion, how do you do it? You end up just with spatial homogeneity to justify the expansion, but you have used the slow motion of galaxies and the CMB global frame to justify that.
Cosmological redshift being coordinate-independent wouldn't help us here according to your stationary coordinate system if you separate the motion of the galaxies from the overall expansion.
I mean if anybody in any galaxy anywhere in the universe can use this global reference frame and has the same preferred choice of coordinates you defined, with no motion relative to overall expansion it could lead to think that expansion is a coordinate property and it can be dispensed with in practice.
Since I don't think you mean that , there must be something I'm misunderstanding. Maybe if you or someone answered directly any of my questions that'd help.
Okay, so,
maybe the issue you're having here is that your argument here seems to be based upon some idea of global motion: that you can sensibly say, in some absolute sense, that
we are stationary, but some far-away object is moving. Or, at the very least, that you can say that some far-away object is moving relative to us.
Neither is the case in General Relativity.
I figure you are probably aware of these facts, but you don't seem to be applying them.
The first point can be summed up with this simple statement: everything is stationary with respect to itself. Furthermore, if you have two objects separated by some distance which, according to one coordinate system are moving with respect to one another, you can come up with an alternative coordinate system where they are stationary with respect to one another. For example, if you really wanted to, you could write down some coordinates where the Sun and the Earth are both stationary. In those coordinates, anything we currently see as evidence of our motion around the Sun would still happen, but would be a result of some other physical effect in the new coordinate system. For example, the seasons would be caused not by the Earth's axis pointing in more or less the same direction but the Earth going around the Sun, instead the twisted space-time around the Sun in this new coordinate system would be applying a torque to the Earth that would cause its axis to precess. All observational effects would still work out the same (General Relativity guarantees this), but they would appear to come from different parts of the equations.
Of course, we
don't make use of a coordinate system where the Earth and the Sun are both stationary, because such a coordinate system would be horribly complicated, difficult to use, and lead to all sorts of strange effects (such as the entire universe rotating around us).
But in the case of the expanding universe, it turns out that a coordinate system where everything is (nearly) stationary
is incredibly useful. The redshift, instead of being due to other galaxies' motions with respect to us, instead comes about just due to the expansion of space in the interim from when the photon left to when it arrived. In this view, photons are expanded by the same effect that is causing the distances between galaxies to increase: new space is being created. So the expansion doesn't go away simply because we've used a coordinate system where everything is stationary, but the observational effect (redshifts) has a different physical explanation in the different coordinate system.
This view, where everything in the universe is nearly stationary but the space between things is increasing, is
exactly the same as the view that we are stationary but everything is moving away from us, and the things further away are moving faster. The two are just different ways of looking at the exact same universe.
However, it turns out that the former view, with everything stationary and space expanding, is one heck of a lot easier to write down mathematically. And it is easier to understand some physical effects in this situation as well, such as the point that brought about this entire discussion: the fact that quasars were once common, but are now rare. In this coordinate system where everything is stationary, the time coordinate for everything is the proper time since the big bang for everything. So if, in this coordinate system, we talk about some event happening 3 billion years ago, then no matter where that event happened, we know it happened 10.7 billion years after the start of our universe
from the perspective of an observer stationed at the event. And when we note that quasars were once common but are now rare, we can understand this as being due to quasar only having enough fuel to be really bright in the early universe, and that fuel later being used up.
