Cosmology - determining if a model universe would recollapse
The problem involves analyzing a cosmological model characterized by specific density parameters (Ω_M0, Ω_Λ0, Ω_R0, and Ω_T0) to determine if it will recollapse in the future. The context is rooted in cosmology, particularly the Friedmann equations and the dynamics of the universe's expansion.
  • The original poster attempts to manipulate the Friedmann equations to derive a cubic equation in 'a' but encounters unexpected results in their plot. Some participants question the definitions and assumptions related to the density parameters and their implications on the model.
Participants are actively engaging with the original poster's attempts, offering clarifications and hints regarding the structure of the equations and the significance of the density parameters. There is a focus on ensuring the correct formulation of the equations and exploring the implications of the curvature term.
There is mention of potential confusion regarding the sum of the density parameters and their relationship to the curvature term. The original poster is encouraged to reconsider the assumptions about radiation and curvature in their model.
James McKeets
Show mathematically that a model with:
Ω_M0 = 3
Ω_Λ0 = 0.01
Ω_R0 = 0
Ω_T0 = 3.01
is a model that re-collapses in the future. Be certain to indicate at what value of the scale factor 'a' the expansion reverses and becomes contraction.
It's hinted pretty strongly that we should probably be using:
( (d(a)/dt ) / a ) = H^2 {Ω_M0 a^{-3} + Ω_Λ0 - (Ω_T0 - 1) a^{-2}}
And that we should be solving a cubic somewhere along the way
So my first plan (I've spent many many hours on this) was to move the 'a' over to the RHS, and then expand out the (d(a)/dt ) using the Friedman equations. This allowed me to reduce the data and find a cubic eq in 'a' such that:
3a^3+0.01a-3=0
However, when I plot this, I get an exponentially increasing line. I was expecting kinda an arch, which would tell me that scale factor has increased, then decreased back to 0.
Any ideas?
If you need more information about the problem, I'd be happy to help, including further information about what I've tried so far.
Many thanks,
James
Hi James:
I have not seen these Ω subscripts before, and I am not sure what they represent. Are you working with the Lambda-CDM model Friedman equation of the form below with
Ωt = Ωradiation = ΩR,
Ωm = Ωmatter = ΩM,
Ωr = Ωcurvature= Ωk, and
ΩΛ = Ωdarkenergy?​
If you are not, then I think that is your problem. I am not sure, but I think the term that is zero should be the curvature term. On the other hand, you may want to set radiation to zero and have a positive curvature.
Also, usually the four Ω coefficients should sum to unity. If they don't, then a0 is not 1.
Good luck, and I hope this helps.
Regards,
Buzz
Hello,
Thank you so much for your reply.
I agree, the format is strange, however it's what we were provided with.
I believe your conversion of subscripts is correct.
I will continue working and post a solution if I find one. Thank you again for your helpJames
ΩHi James:
I suggest you compare your form of the Friedman equation with the one I quoted. I think you left out a "^2". You also need to use a/a0 rather than a, and you need to calculate a0 using the sum of the four terms Ωsubscript × a0n equals 1.
I also just thought another hint that might help you.
You do not need to solve the differential equation for da/dt. Since da/dt is a velocity what do you need to find out to see if the velocity changes to become negative.
Also, note that the value of H0 is not specified. Therefore da/dt must always become negative for any specific value of H0.
If this approach shows da/dt stays > 0, then you need to assume radiation is zero, and curvature is not zero.
ADDED
I noticed that
ΩR + ΩM + ΩΛ = ΩT.​
This suggests that the the curvature term
Ωk = 1-ΩT.​
This means that a0 = 1. See The the end of the "Density parameter" section of
Having a negative curvature makes it easy to show eventual collapse.
Regards,
Buzz
Hi @James McKeets:
I added something to my previous post which you may have missed.
I had one more clarifying idea.
You have an expression H2 = f(a). Taking the square root you get
H = (+/-)√f(a).​
This means that for every value of a where f(a)>0, f(a) can also be <0.
If there is no value of a for which f(a)=0, then the negative values are interpreted as time running backwards.
If there is a value of a for which f(a) = 0, say amax, then there is a corresponding value of t, say tamax.
For this case, think about what da(t-tamax)/dt and a(t-tamax) look like. Are there any symmetries with respect to tamax?
Regards,
Buzz
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 27 ·
