Could someone PLEASE quickly check if my work is right?
  • Thread starter Thread starter Lawcheehung
    Work
The discussion centers on a physics problem involving a 1.00 kg object and a 0.1487 kg object connected by a pulley. The user calculates the final velocity and acceleration of the system, ultimately determining the friction force and coefficient of friction. However, a participant points out that the user incorrectly calculated the final velocity by neglecting gravitational acceleration, suggesting a revised formula for accurate results. The conversation emphasizes the importance of considering all forces acting on the objects to solve the problem correctly. Accurate calculations are crucial for determining the coefficient of friction in this scenario.
Lawcheehung
Basically there's a 1.00 kg object hanging in the air attached to a string which is attached to a 0.1487 kg object that is on a table, and they're connected with a pulley.
the 1.00 kg object pulls the 0.1487 kg a distance of 0.89 m in 1.22 s and then stops when it hits the ground, i need to find the coefficient of friction
ok so..
first i found the final velocity of the object
which is 0.89 m / 1.22 s which gave me a final velocity of 0.7295 m/s
then i found the acceleration of the entire body by doing
a = (vf - vi)/t which gave me an acceleration of 0.597957 m/s^2
The Fnet of the entire body is
Fnet = [(0.100kg ) + (0.1487kg )] * (0.597957 m/s^2)
= 0.14871 N
This is the actual net force with the friction
so the acceleration of the 0.100 kg falling down without the tension should be just
mg = (0.100)(9.8)
= 0.98 N
so the friction force should be
0.98 N - 0.14871 N
= 0.83129 N
This is the friction force.
The coefficient of friction is
Ff = uFn
so 0.83129 N = u(mg)
0.83129 N = u(0.1487 kg * 9.8 m/s^2)
u = 0.5704
Please i need help URGENT
Well I can tell you that you got the final velocity wrong in your first equation. You completely ignored the fact that the object is accelerating under the force of gravity. What you did was the average velocity perhaps.
Try this: Vfinal = Vinitial + at
