Could you check this Li-ion charging circuit?
The discussion revolves around the simulation of a Li-ion charging circuit using circuit simulation software, specifically LTspice. Participants explore the representation of secondary cells in simulators, the specifics of charging time calculations, and the challenges of modeling batteries accurately within a simulation environment.
  • Some participants inquire about the ability to simulate secondary cells, like Li-ion batteries, in circuit simulators and whether they can be represented similarly to capacitors.
  • There are suggestions that SPICE simulators can be used for this purpose, with references to floating voltage sources.
  • Participants discuss the need for specific information regarding the device and application to create an equivalent circuit for simulation.
  • One participant mentions the formula for calculating charging time based on battery capacity and charging current.
  • There is a request for assistance in finding a Li-ion battery component or library for LTspice.
  • Concerns are raised about the accuracy of circuit simulators, emphasizing the importance of correctly modeling components to avoid misleading results.
  • Participants express worries about potential issues in the charging circuit, including the lack of a ground in the model and the implications of short circuits on component safety.
  • Discussions include specific values for component currents and voltages, with some participants questioning the sources of these values.
  • Safety concerns regarding Li-ion battery charging are highlighted, with references to fire hazards and the importance of proper charging practices.
Participants express a range of views on the challenges of simulating Li-ion batteries, with no consensus on the best approach or the specifics of the charging circuit's design. Concerns about safety and component modeling remain contested.
Participants note that circuit simulators require accurate input data for components, and the discussion highlights the limitations of simulations in providing reliable insights without proper characterization of the battery and circuit components.
This discussion may be useful for individuals interested in circuit simulation, particularly those working with Li-ion batteries and seeking to understand the complexities of modeling such components accurately in software like LTspice.
emtae55
TL;DR
I made a Li-ion charging circuit with LTspice, and I wonder if it works well. Could you check this??
Can secondary cell can be described in circuit simulator?? With other symbols like capacitor. Also I wonder if there's a program that provide secondary cell(like Li-ion battery). Please help me
It depends what you mean by “electric simulator”.
SPICE has a floating voltage source.
emtae55 said:
Summary:: Can secondary cell can be described in electric simulator?? With other symbols like capacitor.
Can secondary cell can be described in electric simulator?? With other symbols like capacitor. Also I wonder if there's a program that provide secondary cell(like Li-ion battery). Please help me
What's a "secondary cell"? Do you mean a rechargeable battery? If so, just do a Google search on SPICE simulation rechargeable battery.
We often use equivalent circuits to represent real life devices. For example, a transformer.
But we can't help you to find an equivalent circuit without much more specific information on the device and the application. Do you need to simulate one second? Hour? Year?
I want to know the time for charging it.
The capacity of a rechargeable chemical battery will be specified in amp*hours. If you know the charging current, then you can calculate the time needed to recharge an empty battery.
Hours = (amp*hours) / (charging current)
If you want to simulate the circuit of the charger and battery condition over time, then you should specify the simulator you will use.
LTspice is the most widely used circuit simulator available for free.
https://en.wikipedia.org/wiki/LTspice
I'd like to use LTspice, but I can't find the Li-ion battery component. Would you find me the component(or library)? Thanks.
The thing about circuit simulators is that they do exactly what you set them up to do. They are absolutely not effective at telling you about the components in your circuit. That is the information that you must provide; you must characterize and model your battery. The circuit simulators can tell you how that will interact with other components that you have input into the model. If you program it incorrectly (i.e. unrealistic component models) it will happily simulate the wrong circuit and give the wrong answers; i.e. it will do exactly what you tell it to do.
Batteries of all sorts are typically modeled as capacitors, resistors, voltage sources, etc. If you are lucky you may be able to get access to a battery model that someone else created, but there is no guarantee that it will match the characteristics of your battery.
Circuit simulators are a poor substitute for understanding what you are building, particularly when it comes to individual components of that circuit.
If you take the file.asc and rename it file.asc.txt you can then attach it to your next post, then we can run it to test it. You can do the same with a file.plt by appending .txt
There is no ground for the model. Without ground it will run very slowly due to current sources in the LT317 model.
I worry about current limit to the base of Q1.
Where is the model for the Li ion battery, what voltage is the battery?
Well, because i can change the battery to 18650(standard), so you might not to be worry about that.
I made three points, worry about which?
What if the battery becomes short circuit? then regulator produces 1.2 volts and current is not limited, so the base of Q1 is destroyed.
What range of voltages can the battery be?
Because it's a 18650, it might be about 3.7V.
Also, the max current of Q1 is 50 nano A.
Where do you get that 50 nA value from? Which terminal, under what conditions.
The Q1 collector current during limiting is 1.2V / 470R = 2.55 mA. The base current is then about 25 uA.
But when the battery fails short, (or the terminals are accidentally shorted), the LM317 and battery current will be guaranteed to be more than 1.5A by the LM317 internal limiting, so there will be at least 1.5 volts across the 1R0 current sense resistor, in parallel with the forward biassed base-emitter PN junction of Q1. That is why LM317 data sheets usually recommend a series resistor of about 100R to the base of the Q1 current limiter. That will limit the Q1 base current to about 10 mA which should not destroy the junction.
The LM317 dropout voltage is about 2 volts, the Li cell being charging will be about 3.8V, the voltage drop across the current sense resistor will be about 0.7V, the 1N4001 drop is 0.9V which gives a total of 7.4V, so the charger will need more than the 6 volt supply you have specified.
[Mentor Note -- Two threads on the same subject merged into one]
@emtae55
I see you have now taken your question to the LTspice group.
https://groups.io/g/LTspice/message/123869
That group works with LTspice operation and functionality rather than circuit design advice.
We are not mind readers.
If you want circuit advice you will need to answer the questions asked.
18K
11K
