Calculate Coulomb Barrier Height & Distance with 7.68MeV Alpha Particle
In summary, a scattering experiment involves bombarding gold nuclei with alpha particles and the Kinetic Energy of the alpha particles can be used to calculate the height and distance of the Coulomb Barrier. This can be solved using the formula for conservation of energy, and the distance can be found by equating the initial kinetic energy with the electric potential energy at the barrier.
Beer-monster
296
Its something that I should be able to figure out easily but my brain is refusing to work this term. So any help will be appreciated.
In a scattering experiment, gold nuclei (Au Z=79 A=197) are bombarded by alpha particles (He Z=2 A=4)
If the Kinetic Energy of the apha particles is 7.68MeV calculate the height of the Coulomb Barrier in MeV, and the distance between the alpha particle and the barrier when the particle collides with the barrier.
So can anyone help. I should really be able to do this but my brain is goo, my fault for giving myself an easy summer.
Uh to be more specific I am sure that's the answer is worked out using conservation of Energy, however I'm not sure what formulae to use as everyone I try requires prior knowledge of the distance between the particles, which I don't have.
Have you tried assuming the alpha particles are coming from infinity. The nature of the fields is such that you can start arbitrarily far away and arrive at the same result.
Njorl
I just started studying electricity a few weeks ago so I haven't seen the term Coulomb barrier before, but is that just the point where the repulsion between the alpha particle and the protons in the nucleus becomes strong enough to stop the alpha particle?
If so, wouldn't you solve this by finding the distance from the center of the gold radius at which the alpha particle's electric potential energy is equal to its initial kinetic energy?
Looks a bit like a trick question to me. I'd say, if we know that the alpha collides, then the barrier must be at least 7.68MeV high, or the alpha would go over it. Well, what is the distance of two objects colliding?
(I've been bashed before for answers like this...)
We don't know we have to figure it out in the next question, using the answer to the 1st (I assume)
I don't know it this is any help to you but I had a homework problem like this last week. It didn't refer to the "Coulomb barrier". It just asked how close an alpha particle would get to a gold nucleus if the particle started out at a certain initial velocity (so we had to compute the initial kinetic energy from the given velocity).
In your case, you want
(1/2)mAuvi2 = (keqαqAu)/d
and you are given that (1/2)mAuvi2 = 7.68 MeV
d = (8.99*10^9*2*1.6*10^-19*79*1.6*10^-19)/(7.68*10^6*1.6*10^-19)
d = 2.96 * 10^-14 m
Now, if the "height" of the barrier is defined as the amount of potential energy (and I don't know that this is the definition) you can compute the potential energy at this distance using
U = (keqαqAu)/d
Thanks I'll give that a try
1. What is the Coulomb barrier?
The Coulomb barrier is the electrostatic force that prevents two positively charged particles from coming into close proximity with each other. It is a result of the Coulomb force, which is the attraction or repulsion between charged particles.
2. How is the Coulomb barrier height calculated?
The Coulomb barrier height is calculated using the equation: V = (Z1*Z2*e^2)/(4πε0*d) where Z1 and Z2 are the atomic numbers of the two particles, e is the elementary charge, ε0 is the permittivity of free space, and d is the distance between the particles.
3. What is the significance of the Coulomb barrier in nuclear reactions?
The Coulomb barrier is a crucial factor in determining the likelihood of a nuclear reaction occurring. If the energy of the particles involved is not high enough to overcome the Coulomb barrier, the reaction will not occur. This plays a role in the stability of nuclei and the processes involved in nuclear fusion and fission.
4. How is the distance at which the Coulomb barrier is overcome calculated?
The distance at which the Coulomb barrier is overcome can be calculated using the equation: d = (Z1*Z2*e^2)/(4πε0*E) where Z1 and Z2 are the atomic numbers of the particles, e is the elementary charge, ε0 is the permittivity of free space, and E is the energy of the particles.
5. How does the Coulomb barrier affect alpha particle emission?
The Coulomb barrier plays a significant role in alpha particle emission from a nucleus. The alpha particle, which is a helium nucleus, must have enough energy to overcome the Coulomb barrier in order to be emitted from the nucleus. The higher the Coulomb barrier, the less likely it is for alpha particles to be emitted, and vice versa.
  • Classical Physics
13K
