Coulombs Law, 4 separate charges.
The problem involves calculating the net electrostatic force on a particle (q3) due to three other charged particles (q1, q2, and q4) using Coulomb's law. The charges are specified, and the distances between them are given.
  • Participants discuss using Coulomb's law to calculate forces acting on q3 from the other charges, with emphasis on vector components. There are attempts to break down forces into x and y components, and some participants express confusion about this process.
The discussion includes attempts to clarify the calculation of forces and their components. Some participants have provided guidance on drawing force diagrams and breaking forces into components, while others have expressed uncertainty about their calculations.
Participants are working under the constraints of homework rules, which may limit the type of assistance they can receive. There is an emphasis on understanding the vector nature of forces and the need for accurate component calculations.
Nal101
the particles have charges q1 = -q2 = 296 nC and q3 = -q4 = 198 nC, and distance between each particle is 5.5cm.
Find the net electrostatic force on particle 3
::Answer is required in vector form <x,y,z>::
Using Coulombs law to find the fnet of each particle.
i.e.
eq1 = [(9e9) * 1.98e-7 * 2.96e-7] / .055^2 = force on particle 3 by q2 in x and y direction AND q1 in y direction
eq2 = [(9e9) * 1.98e-7 * 1.98e-7] / .055^2 = force on particle 3 by q4 in x direction
Then adding the forces together, applying the fact that q 1 and q3 repel each other (negative force)
getting <eq1+eq2, eq2-eq1>
The net electrostatic force in q3 is the sum of three forces, one from each of the other particles. First draw these three forces in your diagram. Second, calculate their magnitudes. Third, add them as vectors, all the x-components together (which you must find) and all the y-components together (which you must also find).
That is what I tried to do in my solution, but it came out being wrong. I believe that I am confused on how to find the forces for each x and y component separately.
Draw three arrows with their tails on q3 in the appropriate directions. Break each arrow into x and y components assuming that q3 is at the origin of your axes. When you are ready, show us what you have done so that we can correct it if necessary.
I figured it out.
For anyone wanting to know, to find the x and y components of q2 on q3, you need to take the force and multiply it by cos45 (for x) and sin45(for y) before adding the vectors.
Thank you kuruman
11K
