How Do You Count the Number of Waves in a Ripple Tank Experiment?
  • Thread starter Thread starter roam
    Counting Waves
To count the number of waves in a ripple tank experiment, it is essential to understand that one wave extends from crest to crest or trough to trough, not just from bright to dark patches. The discussion clarifies that while there may be 7 bright patches and shadows in the image, this does not equate to a straightforward count of waves due to fractional wavelengths present. The best practice is to measure a region containing an integer number of wavelengths for accuracy. Ultimately, "one wave" should be defined as the distance between two consecutive bright spots or dark spots. Accurate measurement is crucial for determining the wavelength effectively.
roam
When you shine a light on the ripples in a tank you get dark and bright patches like this:
http://img687.imageshack.us/img687/4343/rippletank.jpg
So my question is: how do we count the number of waves?
In my experiment I am trying to find the wavelength by dividing the distance traveled by a train of waves by the number of waves in it. Do we have to count the number of bright fringes or the shadows?
We are not trying to find the distance from one trough/crest to the next (that would be the wavelength). So, what is "one wave" in this case? How many waves are there in the picture I've posted (I can see 7 bright patches and 7 shadows)? :confused:
Well it's not as simple as just counting bright or dark fringes.
Because an entire wavelength includes both, so in your picture you actually have a fractional amount of wavelengths.
Unless you want to estimate that there are 6.9 wavelengths or something like that then the best thing to do would be to adjust your experiment such that you are measuring a region that you are fairly sure contains an integer number of wavelengths.
But 1 wavelength which is what I would say counts as having "one wave" extends from crest to crest, or trough to trough.
If I start at the first bright spot on the left and go to the next crest that is 1.
So I see 6 full wavelengths in the image.
Then there is a very tiny little sliver on the very left, and also about half a wave on the right side.
So idk... 6.7 waves?
Also, I think you should avoid calling them "waves", and use "wavelengths" instead. That entire thing is one wave, which spans several wavelengths. (of course this last sentence is just semantics, I could be wrong, but that's how I think it goes)
Thanks for the input. They call them "waves" in the pamphlet that describes the experiment. The aim is to find the wavelength by using a ruler to measure the length of as many waves as possible, and then dividing them by the number of waves.
So "one wave" would be just one wavelenght? So, the start of a bright patch to the end of a dark patch would count as one wave?
Sorry I didn't notice you responded sooner, for some reason it didn't notify me.
But "one wave" should be measured from bright spot to bright spot.
Or if you prefer, you can go from dark spot to dark spot. That might seem more intuitive since you are including the entire bright region.
