Couple of Questions Regarding EM Waves
Measuring the E-field and B-field at a point in space can help determine the propagation direction of an EM wave, especially if the wave is monochromatic. A point charge in the path of a sinusoidal EM wave will indeed oscillate due to the force exerted by the wave. The presence of vertical antennas on vehicles indicates that the E-field polarization of the broadcasted radio waves is vertical. Electromagnetic standing waves possess energy and momentum, as long as the cross product between the E and B fields is non-zero. Clarifications confirm that the field is a vector and its properties can be determined through measurements.
virtuosowanaB
I'm a little unsure of my own answers to these questions. Hopefully I'll clear up my misconceptions.
1. If I measure the E-field and B-field at a point in space where there is an EM wave, would I be able to determine the direction it propagates from?
My Ans: I don't think so, since when you do a reading a a point, you only get the scalar value
2. If a point charge +q lies on the x-axis and is in the path of a sinousoidal EM wave, will the point charge move?
My Ans: I believe it would just oscillate at that point
3. Most vehicles have got upright and vertical receiving antennas. What does this tell about the E-field polarization of the radio waves that are being broadcasted?
My Ans: It is vertical.
4. Does electromagnetic standing waves have energy? Does it have momentum?
My Ans: Yes. Yes
Could anyone go through my answers and let me know if I have any misconceptions?
Thanks!
The field is a vector, if you measure it at any point it will still be a vector, if you measure the field at a point you will know about the field at that point, if you also know that the field is monochromatic you will know which direction it is headed towards.
Yes the point charge will experience a force.
Yes as long as the cross product between the E and B fields is non-zero there will be field momentum, all foelds on the other hand have energy.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
