Coupled oscillator: 2 masses and 3 different springs
The problem involves two coupled harmonic oscillators, each with mass and distinct spring constants, connected by an additional spring. The objective is to determine the normal frequencies and describe the normal modes of oscillation under a specific condition relating the spring constants.
  • Mixed
  • Participants discuss the setup of the differential equations governing the motion of the oscillators and explore the relationships between the spring constants and the resulting frequencies. There are attempts to manipulate the equations to find a quadratic form for the frequencies, with some participants expressing uncertainty about their progress.
Some participants have identified errors in their equations and are revising their approaches. There is ongoing exploration of the implications of the relationship between the spring constants, with differing opinions on the complexity of the expected solutions. Guidance has been offered regarding the manipulation of the equations, but no consensus has been reached on the final form of the solution.
The problem includes a specific condition that relates the spring constants, which is under discussion among participants. There are indications of confusion regarding the expected outcomes based on the provided answers in the reference material.
x24759
Two harmonic oscillators A and B , of mass m and spring constants kA and kB are coupled together by a spring of spring constant kC .Find the normal frequencies ω' and ω'' and describe the normal modes of oscillation if (k C)2= kAkB)
The system I have drawn looks like this
wall|---kA---m---kc---m---kb---|wall
with axes XA and XB at the equilibrium position of the left mass and right masses, the differential equations for the motion are:
mx¨A+kAxA+kC(xA-xB)=0
mx¨B+kBxB+kC(xB-xA)=0
After rearranging and ωi=√(ki/m)
A +xA[(ωA)2+(ωC)2]-xBC)2 = 0
and x¨B+xB[(ωB)2)+(ωC)2]-xAC)2=0
(I can't find anywhere on the site how to make a proper x double dot, anyone know?)displacement of each mass with have the form:
xA=Acos(ωt) and xB=Bcos(ωt)
plugging into the differential equations and solving for A/B on each and setting them equal to each other:
ωC2/(ωA2C22)=(ωb2C22)/ωC2
and here is where I get stuck. I have not been able to get the quadratic for ω2 into a form I can work with, so I think I have done something wrong, or there is a better way to go about this problem
If you use LaTeX (recommended) it's \ddot as a prefix to the character(s).
Multiply out your equation, and think of ω2 as the unknown.
That is what I did, not getting anywhere. x=ω2 and A, B, C= ω2A B or Cx2 - x(A+B+C) +[AC+AB+BC]
doing the quadratic formula
x = (A+B+C)/2 ± ½√(A2+B2+C2-3AB-3BC-3AC)
I don't think that is moving in the right directing judging by the answer in the back (ω'2 = (kA+kB+kC)/m and ω''2 = kC/m)
Check the coefficient of C in the middle term.
I found the error, thanks.
the equation is x2 - x(A+B+2C) +[AC+AB+BC] and the roots are x = (A+B+2C)/2 ± ½√(A2+B2+4C2-2AB), which still does not get me to the right answer..
Yes, that's where I got to. I find the book answer doubtful, that there should be a mode that depends only on kC.
Remember, C can be written in terms of A and B.
I read that as only pertaining to the last part of the question. If it is supposed to apply to the first part as well then the book answer is unnecessarily complicated.
I got it. Thanks for the help.
How would you simplify the book answer?
You're right - I was looking at x24759's answer.
ok.
The problem provides kC=kAkB
After the eigenvalue equation is simplified into quadratic form, simplification is trivial, albeit a pain in the a**.
  • · Replies 16 ·
