Coupled Oscillators (Electrical Circuit)
The discussion revolves around solving coupled oscillator equations for an electrical circuit involving two inductors and capacitors. Participants confirm the initial equations for charge dynamics, noting a typo regarding a missing term. They explore the concept of normal modes, emphasizing that the system's equations must yield a linear combination that equals zero, indicating oscillation conditions. The conversation highlights the need to find the relationship between coefficients A and B, leading to the determination of angular frequencies for normal modes. Ultimately, they seek to derive a single equation for ω, which represents the system's oscillation frequency, but encounter complexities in simplifying their expressions.
roam
http://img849.imageshack.us/img849/6315/63685525.jpg
(a) I think since i=dq/dt we will have:
L_1 \frac{d^2q_1}{dt^2} + R_1 \frac{dq_1}{dt}+ \frac{q_1}{c_1}+ \left( \frac{q_1-q_2}{C} \right) = 0
L_2 \frac{d^2q_2}{dt^2}+ R_2 \frac{dq_2}{dt} + \frac{q_2-q_1}{C} = V_s(t)
Are these correct so far?
(b) I'm really confused about this part. I would appreciate any guidance on how to approach this part.
hi roam! :smile:
yes (except you forgot q2/C2)
now look for a linear combination of the two equations that makes the LHS parallel to the RHS :wink:
tiny-tim said:
hi roam! :smile:
Hi Tiny-tim!
Thank you very much. That was a typo, I meant:
L_2 \frac{d^2q_2}{dt^2}+ R_2 \frac{dq_2}{dt} + \frac{q_2}{C_2} + \frac{q_2-q_1}{C} = V_s(t)
So, I'm a bit confused about (b) what should a linear combination of the two equations equal to?
d2(aq1 + bq2)/dt2 + C(aq1 + bq2) = … :wink:
Ah, this expression gives the voltage across the branch in the middle. We need to have the two loops to be parallel. So does this expression have to be equal to Vs(t)?
If so, since the sourve voltage is given by the second equation (that gives a normal mode of oscillation with a frequency determined by L2, R2 and C2):
\frac{d^2(aq_1+bq_2)}{dt^2} + c(aq_1+bq_2) = L_2 \frac{d^2q_2}{dt^2}+ R_2 \frac{dq_2}{dt} + \frac{q_2}{C_2} + \frac{q_2-q_1}{C}
But I tried different values for the constants a and b, there is no linear combination that makes the expression equal to Vs(t). :confused:
If it doesn't have to be equal to the source voltage, what could it be equal to?
hi roam :smile:
(just got up :zzz:)
erm :redface:
you have noticed that (b) says that R1 R2 and V are all zero? :wink:
tiny-tim said:
hi roam :smile:
(just got up :zzz:)
erm :redface:
Hi Tiny-tim,
Ah, so that equation must equal to zero: d2(aq1 + bq2)/dt2 + C(aq1 + bq2)=0
So this has to be satisfied by the angular frequency of the normal mode of the system?
that equation is a normal mode, isn't it? :smile:
Normal mod means that both charges q1 and q2 vary sinusoidally with the same frequency and in phase or out-of phase with respect to each other.
Substitute the trial solution q1=Asin(ωt) q2=Bsin(ωt) into the equations
L_1 \frac{d^2q_1}{dt^2} + \frac{q_1}{c_1}+ \left( \frac{q_1-q_2}{C} \right) = 0
L_2 \frac{d^2q_2}{dt^2} + \frac{q_2}{c_2}+ \left( \frac{q_2-q_1}{C} \right) = 0
You get two linear equations for the coefficients A, B, and ω.
The determinant of the coefficients has to be zero. You find the possible values of ω from this condition.
isn't that the same? :confused:
I do not understand the question. What is the same as what? This system has got two normal modes. They are solutions of the original system of differential equations.
ehild
the same as finding a and b so that d2(aq1 + bq2)/dt2 + C(aq1 + bq2)=0 ?
The normal mode is a solution, not the way of finding it.
What is C in your equation? If it is a constant, you are right, a normal mode obeys the equation q"+w2q=0, and q is a linear combination of q1 and q2. But C means the coupling capacitor in this problem. The notation confuses the OP.
ehild
yes, i meant C a constant
Oh, well... To tell the truth, I do not understand your hints. What do you mean on "to make the two loops parallel"?
ehild
i didn't say that, roam did, i think he was confused because he'd forgotten that in part (b) the non-harmonic non-homgeneous constants were zero :wink:
roam said:
Ah, this expression gives the voltage across the branch in the middle. We need to have the two loops to be parallel. So does this expression have to be equal to Vs(t)? …
Sorry, that was Roam. You said " LHS parallel to the RHS " left hand side and right hand side of what? Of the circuit?
What do you mean about the question c? Is it enough to write up an equation as you suggested d2(aq1 + bq2)/dt2 + C(aq1 + bq2)=0 or is it needed to write the equations in detail with the parameters L1,L2,C1, C2, C(capacitance) given?
ehild
no, of the (combined) equation
… another way of saying, look for for the eigenvalues of the matrix :smile:
not really following you :confused:
a b and C are constants that have to be found
(or do you mean, is my C the same as the C in the question?
no, that was my mistake, i didn't notice C was already in use :rolleyes:)​
I meant question c, the third c already in this problem. :smile:
Well, I have to improve my English, I see. :blushing:
Any hint how to find a,b,C? My old-fashion method gives rather ugly expressions for the eigenvalues.
ehild
ehild said:
I meant question c
but there isn't a question c :confused:
I think he meant the third capacitance, denoted "C" (the other two being C1 and C2). But we need to work out the constants in:
\frac{d^2(aq_1+bq_2)}{dt^2} + k(aq_1+bq_2) = 0
I'm really confused right now. How do I exactly find the equation that must be satisfied by the ω of a normal mode of this system? I'm not sure which way to go...
We eventually have to find explicit expressions for the normal modes of oscillation, but now we are not given any numerical values for the inductances and capacitances.
Sorry, I remembered wrong. So it was question b.
You can write the normal mode frequencies in terms of the parameters, L1,L2,C1,C2,C. Read my post #9. Find the equation for ω. You get a rather ugly expression. I do not think there is a simpler one.
ehild
Thanks. I tried to follow your post #9:
L_1 \frac{d^2(A \sin (\omega t))}{dt^2}+ \frac{A \sin (\omega t)}{C_1} + \left( \frac{A \sin(\omega t)-B \sin (\omega t)}{C} \right) = 0
-L_1 \omega^2 A \sin (\omega t) + \frac{A \sin (\omega t)}{C_1} + \frac{(A-B) \sin(\omega t)}{C} = 0
And the second equation:
L_2 \frac{d^2 (B \sin (\omega t))}{dt^2} + \frac{B \sin (\omega t)}{C_2} + \left( \frac{B \sin (\omega t)-A \sin(\omega t)}{C} \right)=0
-L_2 \omega^2 B \sin(\omega t) + \frac{B \sin(\omega t)}{C_2} + \frac{(B-A) \sin(\omega t)}{C} = 0
Is this what you meant? How exactly do I have to solve for ω in each case? The omegas in the sine arguments are a bit confusing :confused:
You can divide the whole equations with sin(ωt), getting a system of linear equations for A and B.
-L_1 \omega^2 A + \frac{A }{C_1} + \frac{(A-B) }{C} = 0
-L_2 \omega^2 B + \frac{B }{C_2} + \frac{(B-A) }{C} = 0
Collecting like terms,
(-L_1 \omega^2 + \frac{1 }{C_1} + \frac{1 }{C})A-\frac{1}{C}B = 0
(-L_2 \omega^2 + \frac{1 }{C_2} + \frac{1 }{C})B-\frac{1}{C}A = 0
A=0, B=0 is solution (trivial solution) but you want at least one from A and B different from 0. You can determine only the ratio of A and B, one of them is arbitrary, different from zero.
If you studied linear equations, you have to know that for nonzero solution, the determinant of the coefficients must be zero.
If you do not know it yet, find A/B from both equations. They must be equal, which is true only for special values of ω. These are the angular frequencies of the normal modes. Find that equation for ω.
ehild
ehild
Thank you so much, but the ratio A/B I get from the two equations are not equal. From the first equation I get
\frac{A}{B} = \frac{1}{\left( -L_1 \omega^2 + \frac{1 }{C_1} + \frac{1}{c} \right) C}
And according to the second equation it is:
\frac{A}{B} = \left( -L_2 \omega^2 + \frac{1 }{C_2} + \frac{1 }{C}) \right) C
Shouldn't they be equal? :confused:
I also had another relevant question, once we found the the equation that must be satisfied by the angular frequency of a normal mode of this system, how do we find the actual frequency (the frequency of the system itself at which energy is transferred back and forth between the two loops)?
Yes, they have to be equal. Find the value of ω which makes them equal, or at least write the equation for ω.
The system will oscillate with one of those normal-mode frequencies or both.
It is useful to try a numerical solution. Assume that C=1μF, C1=C2=2μF, L1=L2=0.5H.
ehild
I tried to solve for an expression for ω by equating the two equations:
\frac{1}{\left( -L_1 \omega^2 + \frac{1 }{C_1} + \frac{1}{c} \right) C}=\left( -L_2 \omega^2 + \frac{1 }{C_2} + \frac{1 }{C} \right) C
But things turn out to be too messy, because I keep getting a few omega terms and one ω4 and I don't see how it can be simplified in order to have a single equation for ω... So, I'm wondering if this is the correct approach?
At this stage we don't know how many millihenries and microfarads are on the inductors and capacitors, that's why I can't find a suitable ω by inspection. Is there another way to solve this?
Multiplying the whole equation with the denominator and arranging everything on one side, expanding and collecting like terms, you get a quadratic equation for ω2 in the form pω4+qω2+r=0. I think the problem asks only that equation, not the solution.
Coupled oscillators are not easy things.
You would get a more clear picture of the whole thing by solving a numerical example.
Try C=1μF, C1=C2=2μF, L1=L2=0.5H
ehild
Okay. Thank you very much for all your help, that was very helpful. Cheers.
