Covariant Tensor first order, and antisymmetric second order
Telemachus
Hi there. This is my first time working with tensors, so I have to break the ice I think. I have this exercise, which I don't know how to solve, which says:
If V=V_1...V_n is a first order covariant tensor, prove that:
T_{ik}=\frac{\partial V_i}{\partial x^k}-\frac{\partial V_k}{\partial x^i}
Is a second order covariant antisymmetric tensor.
Now, in my notes I have this definitions:
A vector field V is a first order covariant tensor, if under a change of coordinates from x to \overline x it's components are:
\overline {V}=\frac{\partial x^r}{\partial \overline {x}^i}V_r
I think I should use this, but as I said, I'm starting with this, and I don't know how to work this out.
Any help will be appreciated.
Hi Telemachus! :smile:
Write out the barred version of that equation, then use the chain rule to compare one with the other. :wink:
Thank you Tim.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
