Crankcase Supercharging Question
  • Thread starter Thread starter Morgan3
The discussion centers on a Yamada (YS) four-stroke model airplane engine that utilizes a rotary valve to compress the fuel/air mixture, achieving significant boost levels. The engine claims a 30% power-to-weight increase compared to naturally aspirated models. Questions arise about the feasibility of applying this crankcase supercharging method to larger boxer engines, like those from BMW, due to concerns over energy efficiency and potential pumping losses. The idea of using sealed crankcases to minimize losses is debated, along with the practicality of achieving a net gain from the boost. Overall, the conversation explores the balance between potential performance benefits and the inherent inefficiencies of such systems.
Morgan3
There is a four stroke Model Airplane Engine made by Yamada (YS) that uses a rotory valve in the back of the crankcase to compress a fuel/air mixture for two rotations in the valve cover, before it is admitted by the intake valve. The fuel contains oil which lubricates the bottom end. Excluding pumping losses, this would make about 14lbs of boost. YS claims 30% increase to power/weight figures compared to nat. aspirated motors.
My question is whether this has been done with larger boxer engines, like a BMW. It would seem a huge waste of energy to blow and suck the total displacement of the engine overboard with every revolution. Even with pumping losses, it seems a waste of energy. With standard oiling, one could just pump air and use EFI to add fuel at the valve.
Am I missing something or has this been done and proven to be not useful.
PhilD
If the crankcase is sealed there wouldn't be much loss compressing and expanding the air quickly. Pumping it through a valve like your engine would be a different story though.
so, with pumping losses, heating, and other issues, is there a net gain with the boost provided?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
