Asteroid Impact Crater Size: Function of Diameter
In summary, the size of an asteroid crater is not solely dependent on its diameter, but also on its mass and speed. A slower, porous asteroid would have a smaller impact compared to a faster, denser one of the same diameter. The crater size also depends on the material of the asteroid. For more information, check out the links provided.
mersecske
186
What is the crater size for an asteroid impact as a function of the asteroid diameter?
Are there any estimated function?
Astronomy news on Phys.org
I'd expect it has less to do with the diameter than the mass and speed. A slow-moving porous rock would hardly have the same effect as a fast-moving steel object of the same diameter, and a "normal" asteroid of rocky material would be somewhere in between, but would still depend on speed.
The size of an asteroid impact crater is indeed a function of the asteroid's diameter. As the diameter of the asteroid increases, so does the size of the crater it creates upon impact. This is due to the amount of kinetic energy and force that is released upon impact, which is directly proportional to the size of the asteroid.
There are various estimated functions that have been proposed to calculate the size of the crater based on the asteroid diameter. One commonly used function is the "Pierson-Melosh" equation, which takes into account the density and velocity of the asteroid, as well as the strength of the target material. However, it is important to note that these functions are still theoretical and may not accurately predict the crater size in all cases, as the actual impact can be affected by various factors such as the angle of impact, composition of the asteroid and target material, and the atmospheric conditions.
In addition, the size of the crater may also be influenced by the location of impact, as different surfaces and materials may have different levels of resistance to the impact. For example, an asteroid impacting a rocky surface may create a larger crater than one impacting a body of water.
Overall, while there are estimated functions for calculating the size of an asteroid impact crater based on its diameter, it is important to consider all the variables and factors that can affect the actual crater size. Further research and observations are needed to improve our understanding of this relationship.
1. How is the size of an asteroid impact crater determined?
The size of an asteroid impact crater is determined by measuring the diameter of the crater. This can be done using satellite images, aerial photography, or by physically measuring the diameter of the crater on the ground.
2. What factors influence the size of an asteroid impact crater?
The size of an asteroid impact crater is influenced by several factors, including the size and velocity of the asteroid, the composition of the target material, and the angle at which the asteroid impacts the surface.
3. Is there a relationship between the diameter of an asteroid impact crater and the size of the asteroid?
Yes, there is a relationship between the diameter of an asteroid impact crater and the size of the asteroid. Generally, the larger the asteroid, the larger the impact crater it will create upon impact.
4. How does the depth of an asteroid impact crater compare to its diameter?
The depth of an asteroid impact crater is typically only a fraction of its diameter. This is because the force of the impact causes the material in the crater to be pushed outward, resulting in a shallow bowl-shaped depression.
5. Can the size of an asteroid impact crater be used to determine the size of the original asteroid?
While the size of an asteroid impact crater can give an estimate of the size of the original asteroid, it should not be used as the sole method of determining asteroid size. Other factors, such as the composition of the target material, can also affect the size of the impact crater.
  • Astronomy and Astrophysics
