I Crazy steam-hydraulic unit design
The discussion revolves around the design of a high-pressure steam-hydraulic unit, specifically a pressure vessel cylinder measuring 30" in diameter and 36" long, intended to pump hydraulics at 42,000 psi. The creator seeks equations for wall thickness and steam generation temperature at 6,000 psi and expresses a willingness to increase wall thickness by 50-100% for safety and performance. The application is inspired by a tabletop game and aims to create a mobile automaton powered by wood or coal, potentially benefiting lumber mills. Concerns about safety and liability are raised, leading to the closure of the thread. The creator is encouraged to seek local mentorship for guidance on the project.
Prizzard
I can't find equations for wall thickness or required temperature to generate steam at 6000psi. The goal here is a pressure vessel 'cylinder' 30" diameter, 36" long. It will be used to pump 42000psi hydraulics using a piston pump directly driven to a smaller series of pistons to allow the pressure increase.
If anyone can give the required equations and/or information, that would be great! If anyone wants to help with the overall design, I'm open to any input, but I will definitely be ironing out the final design myself. I enjoy the adventure :D
Sounds a bit dangerous, no? What is your level of education and experience with high-pressure designs?
Specifically high-pressure designs, none. I dabble in a lot of basic stuff, primarily projects that get sold or just fail to take off. If this becomes a project I can pursue on my own, I plan to increase the wall thickness 50-100% beyond the recommended both to deal with imperfections in the material and weld and to increase heat capacity to help keep it running under high load. The initial tests of the vessel are to be performed in an isolated area with nobody present until the vessel has had time to cool off. Something akin to a log cabin will be built around the vessel for the test to reduce the distance potential debris can fly.
What is the application? Are there any currently-available off-the-shelf solutions for this application?
The application is a mobile automaton fueled by wood/coal. The original source of inspiration is a total pipedream (See: Warmachine, tabletop miniatures game). I feel some adaptation of this system could be useful to lumber mills and loggers from what I saw during my time in Virginia.
High-pressure systems are more efficient, on-site power generation is more efficient than bringing batteries or hauling fuel. Most power we have ever generated and even now generate is some take on steam power, with the exception of solar panels, wind turbines, and hydroelectric.
It does sound like you are trying to be careful, but for liability reasons we can't allow this thread to continue. Hopefully you can a knowledgeable local Mentor who can help you in person with your project. Please be safe.
Thread is closed.
Likes Nidum
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
