Creating a self propelling wheel
  • Thread starter Thread starter roast beast
    Self Wheel
The project involves creating a hollow wheel with a hidden motor to give the illusion of self-propulsion. The design relies on the motor's force traveling down the wheel's radius, but concerns arise about counteracting the force that would push back against the motor due to Newton's third law. The discussion highlights the importance of understanding the relationship between power, force, and mass, clarifying that watts measure power, not force. It suggests that while the project is feasible, theoretical analysis may not be productive due to real-world complexities; hands-on experimentation with inexpensive materials is recommended. Overall, practical testing is emphasized as a better approach than theoretical calculations.
roast beast
well, not exactly.
I'm working on a little project for school (art school, ironically) and I think I'm a bit in over my rudimentary physics education.
Basically, my idea is to create a wide, hollow wheel with a motor hidden inside of it, so that to the casual observer the wheel appears to moving of its own volition.
My execution is to have the motor and its battery attached solely at the axis, which thus turns the wheel. My understanding is that the force exerted by the motor will travel down the radius of the wheel, gain mechanical advantage, and hit the ground. Due to Newton's 3rd law, that amplified force will bounce back up the wheel and exert force against the motor. So to counteract that, I'll need to have a ballast of some sort connected to the motor with enough mass to negate the acceleration caused by the original force, plus the mechanical advantage. This should prevent the motor from turning uselessly on itself, and the wheel should move forward.
Am I right in believing this?
Further questions:
I'm looking at a twelve watt motor for this, am I correct in assuming for my calculations that it exerts, at any given instant, twelve Newtons?
Newtons per meter per second:
watt = mass*m^2/s^3 = mass*m/s^2 = Newton
will the motor need to exert enough force to accelerate the mass of the entire rig, or simply the mass of the wheel relative to the motor?
Is friction the only limitation on top speed?
Is this project even feasible?
Welcome to PF, Roast Beast.
I'm just on my way to bed, and am somewhat inebriated, so I can't get into this in any detail. One thing that I will mention, though, is that any self-propelled wheel that I've seen has been driven from the inside of the rim rather than having an axle. A definite advantage of that is that you can keep your motor on the bottom to lower your centre of gravity.
No. Watts are a unit for power, Newtons are not, so that part is just wrong.
This kind of project *is* feasible, but I don't think it will be productive for you to try to analyse it theoretically first, partly because the cheap motors and so forth in the real world do not behave in a manner that is quite as simple to describe as for the ideal motors you might consider in a first-year university physics course. Just get some cheap hobby motors, mock up a wheel out of cardboard or similar, and experiment a bit yourself.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
