Calculating EMF and Internal Resistance of a Battery in a Circuit
The discussion focuses on calculating the electromotive force (e.m.f) and internal resistance of a battery in a circuit with two 2.0 ohm resistors. The user initially calculated the effective parallel resistance as 1.0 ohms and set up simultaneous equations to find the e.m.f and internal resistance. After some confusion with isolating variables, they correctly simplified the equations to find that the internal resistance is 1 ohm. Ultimately, the user determined that the e.m.f of the battery is 6 volts. The problem was resolved with collaborative assistance from others in the thread.
Couperin
The question is:
A battery drives a current of 3.0 A round a circuit consisting of two 2.0 ohms resistors in parallel. When these resistors are connected in series, the current changes to 1.2A. Calculate:
a) the e.m.f of the battery
and
b) the internal resistance of the battery.
Here's how far I've got:
I calculated the effective parallel resistance to 1.0 ohms by doing
R=(\frac{1}{2}+\frac{1}{2})^-1
The potential difference in each case is 3V and 4.8V
So I've put them in a simultaneous equation:
Let E be the e.m.f, and r be the internal resistance:
E = 3r + 3
E = 1.2r + 4.8
Which can be written as
3r + 3 = 1.2r + 4.8
But I can't figure out how to isolate the r values!
Any help would be greatly appreciated.
Once you get that far it's just a question of getting your rs on one side and your numbers on the toher...but I don't get teh same equations. Apologies - I've mixed up my series and paralle - it should be exactly as you said.
3r + 3 = 1.2r + 4.8
So
3r - 1.2r = 4.8 - 3
then subs back to find E
Aha! Why on Earth didn't I think of that... :(
Anyway, I got the answer now! Thanks!
3r - 1.2r = 4.8 -3
1.8r = 1.8
r=1
So EMF = 6 and internal resistance = 1
Thanks!
