Current in Series Circuit: .5A Charge Flow?
  • Thread starter Thread starter FS98
    Circuit Current
In a series circuit with a voltage of 5V and resistance of 10 ohms, the current is measured at 0.5A, which represents the charge flowing through a cross-section of the conductor per unit time. Current is defined as the amount of charge passing a point in the circuit per second, and in a series circuit, this current remains constant throughout. The discussion clarifies that the concept of "points" in this context is abstract, as current is measured across a cross-section rather than at discrete points. The physical dimensions of the wire do not affect the measurement of current, which is independent of the wire's size. Understanding these principles is essential for basic circuit analysis before delving into more complex topics like current density and electromagnetic theory.
FS98
If we measure the voltage in a simple series circuit to be 5v and the resistance to be 10 ohms. The current given is .5A. Is this the amount of chage traveling from the first point to the second point per unit time, or is it the amount of charge flowing through a cross section of the conductor between those two points?
Both.
This is very similar to what you asked a few days ago.
Likes FS98
Ampere of current is defined as one coulomb of charge per second. That is what you calculated using Ohm's Law.
Current density is the electric current per unit area of cross section.
Likes FS98
russ_watters said:
Both.
How can it be both? If there was a certain finite amount of charge flowing through the cross section of a wire wouldn’t the amount of charge flowing through a point on that cross section have to be nearly 0?
Also sorry for the similar post, I realized that I was still a bit confused on this topic and it felt like the earlier post was too old to revisit given the slight differences between them.
I think you have a little confusion. The voltage is defined between two points, the current is defined at a single point*. The current at a point is the amount of charge that flows past that point in a unit time.
In a series circuit the current is the same at all points. But the definition of current doesn’t require looking at multiple points. There should be no “two points” here. *technically it is at a cross section through the conductor, but the geometry is neglected in circuit theory
Likes sophiecentaur and FS98
In a series circuit the current is the same at all points. But the definition of current doesn’t require looking at multiple points. There should be no “two points” here.*technically it is at a cross section through the conductor, but the geometry is neglected in circuit theory
But if the amount of charge flowing through a given point per unit time was .5A, wouldn’t the amount of charge flowing through a cross section be infinite because there are an infinite number of points on the cross section?
You didn't ask anything about a point on the cross section, unless you're not understanding the way you used the word "point".
For basic circuit analysis, a wire is one dimensional. It doesn't have a cross section, so a "point" is the entire wire at the one location. if you want the wires to be three dimensional, then the cross section is a slice, not a point. You seem to be mixing and matching, but I don't even understand what these questions are for.
You shouldn't use those meanings of point those ways. Length is Length, area is area, the description that they are made of an infinite number of points is not useful.
No. You're definitely mixing and matching two different geometries. See my above post.
If someone tells you there are ten cars an hour passing along a section of road, you don't have to know which lane they are using. It would be a good idea for you just to go along with the notation and the definitions as they are used by millions of people. You will find that it works very well in most cases. Time enough to go into the details when you have got the basics.
Likes jbriggs444, berkeman and russ_watters
Good analogy. For a basic circuit analysis, you aren't given a wire size (number of lanes) because it doesn't matter.
Current is charge per second. A point is a measure of size, area, volume, length.
The current you measure as being 0.5 amperes is the same wherever in the wire you measure it, irrespective of the dimensions of the wire conductor.
Exactly. Spatial dimensions have nothing to do with it.
Well, actually, you're not measuring at any point. You're measuring all of the cross-section.
"If Is this the amount of chage traveling from the first point to the second point per unit time, or is it the amount of charge flowing through a cross section of the conductor between those two points"
Both are wrong.
Being too concerned about the actual route taken by the current is not advisable when you consider that Alternating Current only travels near the surface of a conductor due to the skin effect. Current distribution over the cross section of a conductor can be highly relevant but you have to get skilled at regular circuit theory before straying into that. It's a big step to get into Maxwell's Equations.
Okay, so, it is the total charge flowing through a boundary per unit time. It doesn't matter how big or small the area is. And, there is no real thing as a point. You're basically confusing math with engineering.
"First point to a second point" is an abstract mathematical concept that doesn't exist.
All wires have a cross section larger that a line. It doesn't matter how big the cross section is in measuring current. Current isn't in units of area.
Current density is in Coulomb's per second per meter squared (C/m*s). Current density is across an abstract boundary of zero area.
What is current in a stream? Is it between two points of the stream or through a cross section? It is liters per second. It doesn't matter how deep or wide the stream is. Current doesn't account for the width of the stream, only the total volume per unit time.
The language in physics is very strict. If you say "cross section", you are including area. If you say, "through a point", you are talking about current density, not current.
Current is Joules per second. That is over whatever size cross-section that the physical wire is. There are no units of area
Current density is in Joules/(s*m^2). It is dependent in how thick the wire is. It is a theoretical measure that can only be calculated. It is "in the limit" as diameter goes to zero.
In circuit analysis, the wire is taken as infinitely thin. Wire diameter only comes in when actually specifying what wire size the purchasing agent should buy. Then, the wire rating becomes important. For the identical current, a thin wire will melt. Bit that also depends on the type of material.
So, you got to get that "current" has nothing to do with physical dimensions. It is through whatever cross section size you mean, from a theoretical point to the width of a lightning bolt.
Now we're getting down to it.
Likes russ_watters
Terms like flux or volumetric flow or flux density come in here and they apply to many different 'flowing' quantities.
Is voltage always measured between theoretical points?
Also, if the physical dimensions of the wire don’t matter when finding this sort of thing, why are wires treated as infinityley thin in circuit analysis? I would think that there wouldn’t be a size assigned if it was trivial.
Are you asking about drawings of circuits or about real circuits? In real circuits you clamp the alligator clips on a piece of wire. In drawings, you select a node. A node is not the same thing as a point, though you can call it one if you like.
In circuit analysis, wires are not treated as having a size at all, infinitely thin or otherwise. They are nothing more than connections between nodes and circuit elements.
Likes FS98
jbriggs444 said:
Are you asking about drawings of circuits or about real circuits? In real circuits you clamp the alligator clips on a piece of wire. In drawings, you select a node. A node is not the same thing as a point, though you can call it one if you like.In circuit analysis, wires are not treated as having a size at all, infinitely thin or otherwise. They are nothing more than connections between nodes and circuit elements.
Just in general when we talk about voltage in ohms law. Can it be between points or between non-points?
What is voltage if we’re not referring to single points? I’ve understood voltage to be a difference in electrical potential between two points.
It's between equipotential surfaces (Google is your friend).
It's between equipotential surfaces. "Points" could only be used if you are talking about thin wires, where the surface area of the wire can be approximate by a "point" on the wire.
Why are you being so obtuse and argumentative?
Likes sophiecentaur
There is no geometry in circuit theory. Neither the cross section nor the length matter. All that matters is its voltage and the current through it. So when I say “point” I am not referring to a 0 dimensional geometric object, there is no geometry in circuit theory.
A “point” in this context is a connection between two circuit elements. Thus “The current at a point is the amount of charge that flows past that point in a unit time” refers to the amount of charge flowing across the connection between two circuit elements.
Likes FS98 and sophiecentaur
The points are normally referred to as 'Nodes'.
Circuit diagrams are symbolic figures. Trying to discuss them in any other way is the equivalent of discussing the typeface used for printing an algebraic equation.
If you are interested in the details of a particular part of a circuit then you can replace a connecting line with a suitable (lowish) 'equivalent' resistor, perhaps, when the real life problem involves very thin wires. Or, if the actual layout of the circuit includes 'dampness', you include a parallel path with a high(ish) resistance from one node to the next.
You have to realize that circuit analysis is outside the real practical world - just the same as arithmetic and algebra. We find some of these things 'obvious' but it's only because we are familiar with maths and circuit theory is a new experience. Just consider the huge problem we all had then we first came across x=y+2.. WTH?
Mods have eagle eyes folks. Watch your typing fingers!
Likes FS98 and Dale
