Solving Current in a Circuit with Kirchhoff's Rules
The discussion focuses on solving a circuit using Kirchhoff's rules, specifically to find the currents through a 14.4Ω resistor and a 23.2Ω resistor. The user applied Kirchhoff's voltage law to derive equations for the circuit, resulting in a current of 1.74A through the 14.4Ω resistor and -0.71A through the 23.2Ω resistor. Feedback from other users confirmed that the calculations were correct, although there was a note about the labeling of currents in the diagram. Overall, the user expressed uncertainty about their approach but received validation for their solutions. The discussion illustrates the application of Kirchhoff's rules in circuit analysis effectively.
kiwikahuna
The currents are flowing in the direction indicated by the arrows. A negative current denotes flow opposite to the direction of the arrow. Assume the batteries have zero internal resistance.
http://img123.imageshack.us/img123/2045/599c898aa10950d7027807dyc7.th.jpg
A) Find the current through the 14.4Ω resistor and the 8.6 V battery at the top of the circuit. Answer in units of A.
B) Find the current through the 23.2 Ω resistor in the center of the circuit. Answer in units of A.
Kirchhoff's Junction and Loop Rules
By applying the Kirchhoff's voltage law to the above loop I get
8.6V - (23.2Ω)I1 - (14.4Ω)I = 0
23.2I1 + 14.4I = 8.6 ........(1)
Applying the Kirchhoff's voltage law to the down loop I get
16.4V + (23.2Ω)I1 = 0
I1 = - 0.71A
Substitute this value in the eq(1)
8.6V + (23.2)(0.71) = 14.4I
I = 1.74A
Therefore the current passes through the battery 8.6V and the resistance 14.4Ω is 1.74A
For Part B, I thought that the current would be equal to I1 which I already solved for in Part A, so the current would be -0.71 A.
I've pretty much worked everything out but I was hoping if someone could tell me if I was doing it right or not. I'm not too confident when it comes to these problems. Any comments would be very helpful. Thanks!
Everything looks good, except for the picture, where all the currents are labeled by the same label (I). The answers are both correct.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
