Damped oscillator with changing mass
The discussion revolves around the dynamics of a damped oscillator with a changing mass, specifically in the context of a homemade experiment involving a cup draining water while oscillating. Participants explore the theoretical underpinnings of the system, including the derivation of equations governing motion and the challenges associated with variable mass in oscillatory systems.
  • One participant describes an experiment using a cup with a hole to create damped oscillations with changing mass, leading to questions about the oscillation time.
  • Another participant suggests that determining the function for mass over time, m(t), is crucial for formulating the governing ordinary differential equation (ODE) for the system.
  • Concerns are raised about the complexity of the resulting non-linear ODE and the potential need for numerical methods to solve it, especially if the air resistance term is included.
  • There is uncertainty regarding the inclusion of the term involving the rate of change of mass and velocity in the ODE, with participants expressing differing opinions on its necessity.
  • Some participants propose simplifying assumptions to treat the draining water as a static system, suggesting that the accelerations may be negligible compared to gravitational effects.
  • Discussion includes the nature of the damping force, with suggestions that it should be modeled linearly rather than quadratically due to the expected modest speeds involved.
  • Participants express interest in the fluid mechanics aspects of the problem, noting the complexity of m(t) as it relates to factors like water volume and hole diameter.
Participants express differing views on the formulation of the governing equations and the treatment of the mass change. There is no consensus on the correct approach to include the variable mass term in the ODE or the nature of the damping force. The discussion remains unresolved regarding the best method to derive the oscillation time.
Limitations include the lack of prior coursework in oscillations and computational physics for some participants, which may affect their ability to solve the problem numerically. The complexity of the ODE and the assumptions made about the system's behavior are also noted as potential challenges.
This discussion may be of interest to undergraduate students studying dynamics, fluid mechanics, or those exploring experimental physics involving oscillatory systems and variable mass scenarios.
  • #61
In a broad sense, I agree that a system is defined by people. If we define a system that only considers the force and momentum remaining inside the cart, even though the cart is losing mass, then I wouldn't think the statement that Newton's second law does not apply to this system is false. Because the basis of Newtonian mechanics is the conservation of mass, since this system is not an isolated system, it interacts with other systems, and its mass is not conserved, we cannot apply Newton's laws to this non-isolated system.
This is certainly not a problem of Newtonian mechanics, not a problem of equation ##F=m\frac{dv}{dt}+v\frac{dm}{dt}##, nor a problem of system definition, because I think one has the right to choose the parameters involved in defining the system (including non-isolated systems).
For the entire isolated system.
$$\sum F = \frac{dp_1}{dt}+\frac{dp_2}{dt}=\left(m_1\frac{dv}{dt}+v\frac{dm_1}{dt}\right) +\left(m_2\frac{dv}{dt}+v\frac{dm_2}{dt}\right)=m_0\frac{dv}{dt}+v\frac{dm_0}{dt} $$Since ##~\sum F ~## and ## ~\frac{dm_0}{dt}~## are equal to zero, ##\frac {dv}{dt}=0 ~~ ##:smile:
  • #62
bob012345 said:
Newton's Second Law always works in every situation and on every part of a system
I doubt Newton even considered systems of varying mass. We can either specify that Newton 2 only applies to constant mass systems (my preference) or specify how to adjust it to cope with them.
@Orodruin's fix (post #22) is to say that mass entering or exiting the system with its own momentum constitutes a force on the system. I have not seen that elsewhere, but maybe it is standard.
  • #63
In what sense is this used? I remember my Physics professor making a point about Newtons 2nd Law actually being:
$$ \sum F = \frac{d}{dt} \left( mv \right) $$
Yet we never used it that way ( as far as I can tell, or remember )
Is it just the basis for the derivation of Impulse/Momentum?
$$ \int \sum F dt = \int d ( mv ) = m_f v_f - m_o v_o $$
  • #64
I mean, effectively Newton's second law is just a definition of force as the rate of change of a system's momentum. By itself it does not tell you very much. Only once you start modelling the forces does it actually give you a physical model. So, we define force as the rate of change in a system's momentum. How then can a system's momentum change? We can have contact or volume forces that transfer momentum between different systems and model those - and we can have momentum leaving a system by having material flowing out of the system and taking some momentum with it. The only question is what you decide to call "an external force" on a system.
  • #65
Do we? I always thought a force has some physical basis and causes a change in momentum when it acts on some object.
  • #66
I have seen the argument recently that Newton's Second Law in the differential form doesn't apply to systems of changing mass because of Galilean invariance. Comments?
https://physics.stackexchange.com/questions/53980/second-law-of-Newton-for-variable-mass-systems
  • #67
  • #68
erobz said:
That argument is also in the paper you linked. Section 2. Variable-mass systems and Newton’s second law
http://www.scielo.org.mx/pdf/rmfe/v60n1/v60n1a3.pdf
Sure but their situation is different from the cart leaking water 90 degrees to its motion.
They also make this claim
In order to correctly obtain the equation of motion, we have to apply the principle of conservation of linear momentum for the entire system, which is the basic principle behind the Newton’s second law
So, they are changing what Newton said too. Not saying it's 'wrong' just saying it's a different perspective.
  • #69
You need to model a force somehow to even put it into Newton's second law. For example, what Newton's law of gravitation tells you is that the rate of momentum exchange between two bodies is given by ##\pm GMm/r^2##.
In statics problems in mechanics, you are essentially modelling the forces by requiring them to be contact forces at particular points (or spread out loads) and asking what their magnitudes must be for a particular configuration to be in equilibrium.
Without a model for the forces involved, Newton's second law does not really tell you anything except that there is something called "force" that is a change in an object's momentum.
  • #70
"net force" correct?
  • #71
That's what I said or meant but I wish the language used made it more clear that a physical force causes a momentum change, not the other way around.
  • #72
A force is a momentum flow rate. This is the point.
  • #73
Any force is a momentum change rate. What is true is that the total change rate for an object’s momentum is the sum of all individual contributions and so the net force is the total change rate of the object’s momentum.
  • #74
You said "momentum change", not "momentum change rate" in what I quoted. Any "force" will not necessarily change the objects momentum, but a "net force" will. Not that it matters.
  • #75
That was just sloppiness. Force is momentum change rate, not momentum change. Momentum change is the time integral of the change rate, ie, impulse.
Momentum change is not a force.
  • #76
What about static forces?
  • #77
They are also flow rates of momentum. It just so happens that in a static situation the net flow of momentum into an object is zero. In the static case you have p=0 and therefore dp/dt=0. This puts constraints on the momentum flows in/out of the object - they have to add up to zero.
  • #78
I said to myself when I mentioned static forces that someone here would probably suggest momentum flows adding up to zero. Your answer here almost created a non-zero momentum flow between me, my chair and the floor!
So, I was going to ask you to find at least one academic or published source for that concept of static momentum flows but I found some myself. Both papers are from the same source and I found no others so while this is an approach that has been published, I doubt if it is standard fare in engineering statics courses.
http://www.physikdidaktik.uni-karlsruhe.de/download/statics_momentum_currents.pdf
https://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.572.3896&rep=rep1&type=pdf
Essentially, if I understand it, the concept tries to do away with forces altogether and replace them with an electric current analog.
  • #79
There is no need to replace anything. It is just a question of writing down the continuity equation for momentum. This is commonly done in, for example, fluid dynamics in the Euler equations.
Edit: Or more generally, the Cauchy momentum equations. These describe non-relativistic momentum transport in any continuum.
It is a simple matter of looking at the continuity equation for momentum in any static situation. This is not in any way controversial or strange but certainly not the way that introductory mechanics courses would look at things simply because you don’t need to. The momentum current is the stress tensor and the momentum density is zero. With momentum being conserved, it is inevitable that you obtain a corresponding continuity equation on the form change = amount in - amount out + amount sourced.
Another way of seeing this is that even in a static situation any force acting on an object will give an impulse over time. This is a transfer of momentum by definition. That the object does not start moving is because the opposite impulse was transferred to the object somewhere else (or equivalently, by the third law, the impulse was passed on to another object).
What you do need to do in an introductory class is to model your forces or Newton’s second law will not help you.
  • Wow
  • #80
Interesting stuff. A bit over my head. Is there a "mechanics of momentum flow" where the "fluid type" model is utilized regularly?
Never mind. I see your edit. Definitely over my head!
  • #81
Great. So, getting back to the problem at hand, first, how would you attack the dripping cart problem? There seems to be a consensus among others here that Newton's Second Law simply does not apply to the cart and remaining water it carries because the mass is changing.
  • #82
That’s not really true. Newton’s second law does apply. You just have to apply it correctly and include all momentum flows - including those resulting from momentum being transported out of the system by the mass lost. This is also included in the Cauchy momentum equations in the continuity form by the term ##\rho \vec u \otimes \vec u## in the momentum current.
I have already described in this thread how that would apply to a mass loss with a general ejected velocity (which is significantly simpler than solving the Cauchy momentum equations but still requires somehow modelling the ejected velocity).
  • #83
You need to solve two differential equations simultaneously. One models the water flowing from the cup and the other models the position of the cup. Use Runge-Kutta to solve numerically.
  • #84
Ok, thanks. I thought it did. But don't we agree the cart will not speed up or slow down at all as the water falls out? It just gets lighter as the water leaks but maintains its velocity. We model the water leakage rate independent of the cart dynamics.
Orodruin said:
This is - as many times - only a problem if one misinterprets that equation. With ##F## being the rate of momentum change in the system, the case of just dripping does not satisfy ##F=0## because momentum is leaking out of the system with the mass at a rate of ##-\dot m u##, where ##u## is the velocity of the leaking mass. For ##u=v## we obtain ##\dot v=0##.
For ##u=v+u_0##, we do end up with an acceleration of ##-[d\ln (m/m_0)/dt] u_0##.
In this post #22, you appear to be saying the loss of momentum as water drips will cause an acceleration of the cart?
  • #85
More specifically, two coupled non-linear differential equations in the typical case.
  • #86
That depends on how the water leaves the cart. If it leaves the cart with the same velocity as the cart, then Newton’s second law would tell you that ##ma + \dot m v = \dot m v##, ie, ##a=0##. If it leaves at any other velocity it is that velocity that enters the RHS giving rise to ##ma = \dot m(u-v)##.
Which it will in the general case. The expression quoted is just the Tsiolkovsky rocket equation based on ejecting mass at a constant relative speed.
  • #87
Just to be clear, you are referring to the "leaking bucket oscillator" problem in the OP
  • #88
I see. I was assuming it leaves with the same velocity as a limiting case of slowly dripping.
Yes, the component of the velocity of the water leaving along the carts motion would act as a rocket.
  • #89
erobz said:
Don't you still have to choose a direction? In the case of the cart dripping water from the bottom, the total momentum ( cart + drop) in the direction of motion remains constant. That is to say the mass flowrate in the direction of motion is zero. Sure, the cart is losing mass, but its not going to change velocity.
For the draining cup the mass flowrate in the direction of motion is non-zero, and there will be an impulse in the direction of motion from the fluid jet.
And something seems to be mis applied in taking
$$ \sum F = \frac{dM}{dt} v + M \frac{dv}{dt} $$
The Rocket Equation is derived from impulse in a stationary frame of reference ##O## :
$$ \sum F = \frac{dM}{dt} v_{e/R} + M \frac{dv}{dt} $$
The ## v ## in the first would be with respect to ##O##: i.e. ## v = v_{e/O}##
If in doubt go back to first principles. To derive equations of motion in mechanics it's safe to say that the fundamentals are the conservation laws based on the symmetries of the Galilei (or Poincare for special-relativistic mechanics) group. The equations of motion follow from the conservation of momentum (i.e., symmetry of the physical laws under spatial translations) for a closed system.
For the rocket equation, see, e.g.,
https://www.planetary.org/articles/20170428-the-rocket-equation-part-1
In the case of the cart the relative-velocity component of the dripping water in the direction of the cart's motion is 0 and thus the velocity of the cart doesn't change, as discussed already above.
  • #90
I would like to actually try to set up the equation for the leaking bucket on a spring, neglecting the fluid jet thrust and drag. I'm not fully understanding the result that was linked and was hoping someone would guide me through it.
Firstly, where do we take the coordinate from ##x## from? Does it matter? I have it shown from the ceiling the top of the cup.
The equilibrium position ## x_o## is a function of time:
Let
## M(t) = m_w (t) + m_b ##
$$ x_o (t) = \frac{ \left( m_b+m_w(t) \right) g}{k} =\frac{ M(t) g}{k} $$
Where:
## m_b## is the mass of the bucket
## k## is the spring constant
## m_w ## is the mass of the water in the bucket at time ##t##
Ignoring the thrust from the jet:
Is (1) the proper differential equation?
$$ M(t) \frac{d^2}{dt^2} \left( x- x_o(t) \right) = M(t) g - k \left( x- x_o(t) \right) \tag{1} $$
  • · Replies 36 ·
  • · Replies 20 ·
