Dangers of high current/voltage?
  • Thread starter Thread starter user111_23
High voltage and high electrical current are only dangerous when they exceed circuit capacity or when individuals lack proper knowledge. High voltage itself is not intrinsically hazardous; for instance, a Van de Graaff generator can produce thousands of volts safely. However, when a circuit is opened under load, as demonstrated in a linked video, it can lead to dangerous situations like plasma fireballs. The real danger to living beings arises from the power involved, particularly when current flows across the body, which can be lethal. Understanding the principles of electricity is crucial for safety in handling high voltage and current situations.
user111_23
Why is high voltage dangerous in a circuit? Similarly, why is high electrical current dangerous in a circuit?
It's only dangerous if it exceeds the circuit capacity, or someone does not know what they are doing.
Like the squirrel: http://www.youtube.com/watch?v=0XBurkUkdFE&NR=1
Someone who knows what they doing can hang onto 500,000 volts:
Same answer: It's only dangerous if it exceeds the circuit capacity, or someone does not know what they are doing.
The following two gentlemen appear to have opened a circuit breaker which had a large current flowing through it: http://www.youtube.com/watch?v=h10ALIpD0R4&feature=related
As long as the circuit was closed, thousands of amps could flow safely. As soon as the switch was opened, a plasma fireball was ejected, which probably injured the two men.
In terms of danger to living beings, high voltage isn't intrinsically dangerous. A Van de Graaff generator can easily create potential difference of thousands of volts and more, and yet is safe (although I wouldn't want to touch a charged one!). It's the power (P=I^2*R=V^2/R) that fries you if you happen to touch a bare wire.
Assaf
http://www.physicallyincorrect.com"
Burns from electrical contact can be treated. Enough current (more than a few milliamps) flowing across your upper torso (like from hand to hand, or hand to foot) can stop your heart.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
