Dark Matter Black Holes: Is it Possible?
In summary: And that’s the tough reality of it:Black holes form almost entirely out of normal matter no matter where they form."False. A small percentage of black holes are probably made of dark matter, but that's basically it.
James S
is a dark matter black hole possible, and what would it be like ?
Could dark matter be a multitude of microscopic black holes?
As far as I know it would be just like a regular black hole.
If you mean, can you make a black hole by collapsing dark matter, sure, you can make a black hole by collapsing any kind of matter.
If you mean, can you make a black hole "made of" dark matter, black holes don't work that way. See below.
A black hole of a given mass is the same regardless of what it was made from--once the hole is formed, there's no way to tell from the outside what kind of matter collapsed in order to make it. So a black hole that was formed from collapsing dark matter would be the same as a black hole formed from collapsing anything else.
Likes |Glitch|
From what I've read, black holes can only be made of a very small % of dark matter.
Where did you read that?
To add to what has already been said, although a black hole could be made of dark matter, it is extraordinarily unlikely that dark matter WOULD form a black hole because dark matter doesn't clump the way normal matter does.
thanks to all
Observational data seems to confirm this view. There is a strong correlation between the rate of consumption of conventional, visible matter from accretion disks and the consequent estimated mass of feeding black holes. So, unlike the rest of the universe, where dark matter seems to dominate conventional matter by a factor of five, black holes seem to be primarily built from the consumption of conventional matter.
Can Dark Matter Form Black Holes?
http://www.americaspace.com/?p=33773
In his blog the astrophysicist Ethan Siegel also wrote:
While dark matter might be responsible for up to 16% of a black hole’s growth out where we are, it could only, at most, be responsible for 0.004% of a black hole’s growth at the galactic center. And that’s the tough reality of it:
  1. Black holes form almost entirely out of normal matter no matter where they form.
  2. The ones that form where the density of matter is low — like out where we are — will have a substantial portion of that growth come from dark matter, but that growth is (on average) negligible compared to the initial black hole’s mass.
  3. The ones that form where the density of matter is high — like near the galactic center — will experience significant growth, but at least 99.996% of that growth comes from normal matter and not dark matter.
...And there you have it: a quantitative answer to the question of whether black holes are made of dark matter or not. At most they can only be made of about 0.004% dark matter, and that’s the most optimistic number that applies only to the most massive ones!
Ah, I see. It's not that a black hole can't "accept" dark matter; it's just that, since dark matter interacts so weakly with anything else, it's much harder for it to fall into a black hole the way ordinary matter does (by losing energy through interactions and radiation).
Link please?
bohm2 said:
This is a good example of why you can't trust pop science articles, even when they're written by scientists who are experts in the field. Nothing he says in here is wrong, exactly, but it's just brimming with opportunities to be misconstrued. Examples:
"Some days may see a black hole grow by a tremendous amount, while others may see it shed more mass-and-energy than it gains!"
Technically true (at least if you accept that Hawking radiation is possible, which practically all physicists do even though it's never been observed); but practically false, since in order to shed mass by Hawking radiation in our current universe a black hole would have to have a temperature greater than the temperature of the CMBR--otherwise it will gain mass from the CMBR faster than it loses it from Hawking radiation. The black hole mass corresponding to this temperature is about the mass of the Moon, far smaller than any black hole we have observational evidence for (those are all stellar mass or larger, sometimes much larger); so all black holes we know of will gain mass from the CMBR far faster than they lose it from Hawking radiation, even if nothing else ever falls into them.
(Note that the article, towards the end, talks about how long it would take a stellar mass black hole to evaporate by Hawking radiation, but still doesn't mention that it won't lose any mass at all, on net, until the CMBR temperature becomes smaller than the black hole temperature. That's governed by the expansion of the universe, not the properties of the black hole.)
"If we had enough mass in a small enough region of space, the escape speed something would need to reach could be greater than 299,792,458 m/s (670,616,629 mph), which is the speed of light in a vacuum. Since nothing can travel faster than that speed, nothing would be able to escape from it, not even light. Hence, you’d have a black hole."
Again, technically true, but misleading because it implies that a black hole is a static object like a planet or star, just more compact so that gravity is strong enough at its surface to keep light from escaping. A black hole is not like that at all. It has no "surface", and the event horizon, where the "escape velocity" equals the speed of light, is not a "place" in the ordinary sense (it's a null surface, so it's better thought of as an outgoing spherical shell of light). To be fair, this misleading picture is in a lot of pop science articles by scientists, so it's not just this one person's fault; but it's still misleading.
"So initially, when they’re first formed, black holes are pretty much 100% normal (baryonic) matter, and just about 0% dark matter."
This is true of black holes formed by the process he describes (collapse of the core of a supernova when it runs out of nuclear fuel), but we don't know if all the black holes in the universe were formed by that process, or by mergers of black holes formed by that process. In particular, we don't know that the supermassive black holes at the cores of galaxies and quasars were formed by that process; they may have been formed by a different process that involves dark matter to a greater extent. And these supermassive black holes might actually account for much more mass, in the universe as a whole, than black holes formed from stellar collapse. So this statement is not so much misleading in itself as seriously incomplete.
Yeah, I got that far and quit reading immediately.
When he says "enough mass in a small enough region of space", he does mean ordinary matter. The black hole singularity will form as a result.
Why do you think it should be restricted to ordinary matter? You got something against dark matter ? :smile:
I was defending Siegel against one of Peter's criticisms. I just don't know how to quote a post in this forum.
It would definitely appear as a regular black hole, because it does not matter what material the black hole is actually composed, we can only see to the event horizon and no further.
There's a Quote button at the bottom right of each post, and if you highlight some text in a post, a "Quote" button appears below the highlighted text. Then use the "Insert Quotes" button under the text box where you enter your reply.
hey, it works! Thanks!
1. What is dark matter and how is it related to black holes?
Dark matter is a hypothetical type of matter that does not emit or absorb any electromagnetic radiation, and thus cannot be directly observed. However, its existence is inferred from its gravitational effects on visible matter. Black holes, on the other hand, are regions of space with such strong gravitational pull that even light cannot escape from them. They are formed when a massive star collapses in on itself. Some theories suggest that dark matter could be made up of primordial black holes, which are thought to have formed in the early universe.
2. How are black holes formed?
Black holes are formed when a massive star runs out of fuel and collapses under its own gravity. As the star collapses, its core becomes denser and denser until it reaches a critical point where the force of gravity is so strong that it traps even light. This creates a singularity, a point of infinite density, at the center of the black hole. The size and mass of the black hole depend on the size and mass of the star that formed it.
3. Is it possible for dark matter to form black holes?
While it is possible for dark matter to form black holes, it is still a subject of scientific debate and research. Some theories suggest that primordial black holes, formed in the early universe, could be made up of dark matter. However, there is currently no direct evidence to support this idea and more research is needed to understand the relationship between dark matter and black holes.
4. Can we detect dark matter black holes?
Since dark matter does not emit or absorb any electromagnetic radiation, it is very difficult to detect. This also applies to any potential black holes made of dark matter. However, scientists are constantly developing new ways to indirectly detect dark matter through its gravitational effects on visible matter. If dark matter black holes do exist, they may be detected through these indirect methods in the future.
5. How does the existence of dark matter black holes impact our understanding of the universe?
If dark matter black holes are proven to exist, it would significantly impact our understanding of the universe. It could provide insight into the nature of dark matter and its role in the formation and evolution of galaxies. It could also help us understand the mysterious gravitational forces that hold together galactic structures. Further research and evidence are needed to fully understand the implications of dark matter black holes on our understanding of the universe.
  • Other Physics Topics
11K
9K
