Dayton 2A562 Time Delay Relay: 3-60 Secs On/Off?
The discussion centers around the functionality of the Dayton 2A562 Time Delay Relay, specifically whether it waits for a period of 3 to 60 seconds before powering on or if it powers off after that duration. Participants are exploring the operational characteristics of the relay, including its contact types and potential alternatives.
  • One participant seeks clarification on whether the Dayton 2A562 waits 3 to 60 seconds before powering on or powers off after that duration.
  • Another participant mentions that there are many references available online regarding the relay, noting that it has normally open (N.O.) contacts.
  • A participant argues that the information about N.O. contacts does not clarify how the timer operates, questioning whether it is active during the waiting period or after.
  • One participant suggests that the relay implies the contacts remain open until the set time period is reached, at which point the contacts close.
  • Another participant proposes a specific operational scenario where the load receives power when input power is applied, and the load is switched off after the time interval elapses, indicating that the Dayton 2A562 may not meet this requirement.
  • This participant recommends using an "on delay" relay with normally closed contacts as an alternative, suggesting a different model that would fulfill the described needs.
Participants express differing views on the functionality of the Dayton 2A562, with some believing it does not meet the desired operational criteria while others provide interpretations of its contact behavior. The discussion remains unresolved regarding the specific operational characteristics of the relay.
There are assumptions about the relay's operation based on the type of contacts and the desired functionality, but these assumptions are not universally accepted among participants. The discussion does not clarify the exact mechanics of the relay's timing function.
Southerner
Can someone please tell about the Dayton 2A562 Time Delay Relay.
Does it wait 3 to 60 seconds before powering on, or does it wait 3 to 60 and then power off?
I am looking for something that will run for 3 to 60 seconds and then shut off.
thanks
thanks
did you do a google search ? there are many references
one I looked at stated it has a set of normally open contacts
Dave
Yes, but just because it says N.O. contacts that still doesn't answer the question of how the timer works-the the it's active or the time it waits before it's active...
well from my understanding it does :)
it implies that the contacts are open (N.O. = normally open) till the time period set is reached and then the contacts close
Dave
I'm assuming what you want is the following: When input power is applied the load receives power. When the time interval has elapsed the load is switched off. When input power is removed the cycle repeats.
If the above is what you want then you can use an "on delay" with normally closed contacts. I don't think the solid state relays will do this. However, this mechanical one will:
http://www.drillspot.com/products/425611/Dayton_1EGB3_Relay
The 2A562 will not do what you want.
THANKS! I knew one must exist like that...
  • · Replies 31 ·
