How to Achieve DC Biasing in a MOSFET Rectifier Design?
DC biasing in a MOSFET rectifier design is crucial for achieving high sensitivity, particularly in low input power scenarios. The design requires the transistors to operate in the sub-threshold region, which allows for efficient performance despite low input voltages. Understanding sub-threshold conduction is essential, as it enables the transistors to function effectively rather than simply acting as a switch. Resources for learning about DC biasing and sub-threshold operation in analog circuits are recommended to aid in the design process. Mastery of these concepts will facilitate the development of a high-performance rectifier.
Peiqii Tan
Hi there,
I m a beginner in Analog IC design field. Currently, I have a project which is to design a high sensitivity rectifier by using Synopsys simulator. However, I m stuck in the beginning part which is the DC biasing of MOSFET transistor.
The design specification as below:
Technology : 130nm
Frequency : 900MHz - 2.4GHz
input voltage : 0.2V - 1.0V
sensitivity : -32dBm
PCE : greater than 80%
1. How to do DC biasing? how to start it? Is any link can provide? Is it different with the amplifier design?
2. As mentioned in the journal, in order for rectifier to work with very low input power, all the transistors of rectifier should operate in the sub-threshold region. I m not clear with this part, suppose sub-threshold region will have no conduction path between drain and source. How could it able to trigger the transistor?
What journal?
From wikipedia: https://en.wikipedia.org/wiki/Subthreshold_conduction
"In digital circuits, subthreshold conduction is generally viewed as a parasitic leakage in a state that would ideally have no current. In micropower analog circuits, on the other hand, weak inversion is an efficient operating region, and subthreshold is a useful transistor mode around which circuit functions are designed"
You need to research and understand subthreshold analog circuits.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
