How to Find the X Component of a Vector | Decomposing Vectors Homework
  • Thread starter Mr Davis 97
  • Tags
    Vectors
In summary, when finding the x component of a vector that is pointing in a direction specified in degrees, there are two ways to do it. One way is to tack on a negative sign and calculate -(magnitude)cos(angle). The other way is to not tack on a negative sign and calculate (magnitude)cos(180-angle). Either method is acceptable, as long as you are aware of the direction and use the appropriate angle in the cosine function.
Mr Davis 97
1,462
44
The magnitude of the vector is 6 m, and points 35 degrees north of west. Find the x component of the vector.
x = |R|cos(theta)
I am confused about what degrees to input into the cosine function. I know that the vector is pointing 35 degrees north of west, which means that the x component will be negative, but there are two ways I could do it am I am not sure which one I should do. First, I could tack on a negative and calculate -(6 m)cos35 = -4.9 m. Another way is not tack on a negative and calculate (6 m)cos145 = -4.9 m. Which method is better, and which one should I use on a regular basis?
Both ways are fine, as long as you don't try to memorize a rule and blindly apply it. Personally, I like the first approach, and just tack on the negative sign when I know there should be one.
x = |R|cos(theta)
Well, you could learn the angles for the cardinal points of the compass, but why do that when you can just make something up?
East = 0°
North = 90°
West = 180°
South = 270°
East = 0°
North = 90°
West = 180°
South = 270°
Huh?
Mr Davis 97 said:
Huh?
You've never seen the following diagram (or a similar one)?:
It should have been used when you studied trigonometry.
After all,
cos (0°) = 1.0
sin (0°) = 0.0
cos (90°) = 0.0
sin (90°) = 1.0
cos (180°) = -1.0
sin (180°) = 0.0
cos (270°) = 0.0
sin (270°)= -1.0
etc., etc.
1. What is the X component of a vector?
The X component of a vector is the horizontal length or magnitude of the vector. It is the projection of the vector onto the X-axis.
2. How do you find the X component of a vector?
To find the X component of a vector, you can use the formula X = |V| * cos(θ), where |V| is the magnitude of the vector and θ is the angle between the vector and the X-axis.
3. Can you decompose a vector into its X and Y components?
Yes, a vector can be decomposed into its X and Y components using trigonometry. The X component is the horizontal projection of the vector and the Y component is the vertical projection.
4. Why is it important to find the X component of a vector?
Finding the X component of a vector is important in many applications, such as physics and engineering. It allows us to analyze the motion of an object in a specific direction and calculate the forces acting on it.
5. What is the difference between the X component and the Y component of a vector?
The X component of a vector is the horizontal projection of the vector, while the Y component is the vertical projection. They are perpendicular to each other and together make up the magnitude and direction of the vector.
