Defenestration homework not going so well -_-
  • Thread starter Thread starter liagee
    Homework
A ball is thrown horizontally from a height of 53.8 meters and strikes the ground 119 meters away, with gravity at 9.8 m/s². The time of flight is calculated as 3.3135 seconds, but the user struggles to find the initial velocity and the x and y components of the velocity before impact. They express confusion over which kinematic equations to use, particularly for horizontal and vertical motion. The discussion highlights that acceleration affects the y-direction only, while the x-direction remains constant. The user seeks clarification on the correct formulas and concepts related to the problem.
liagee
A ball is thrown horizontally from the top of
a building 53.8 m high. The ball strikes the
ground at a point 119 m from the base of the
building.
The acceleration of gravity is 9.8 m/s. The time (I got this answer and it's correct and all) is 3.3135sec.
(part 2 of 4) Find the initial velocity of the ball.
(part 3 of 4) Find the x component of its velocity just before it strikes the ground.
007 (part 4 of 4) 10.0 points
Find the y component of its velocity just before it strikes the ground.vaverage = d/t
a = Vdelta/t
vf = vi + at
I don't even know any others -_-
I tried to use vf^2 = vi^2 + 2ad?? It didn't work. I am really lost but if someone could tell me which formula (kinematics) to use that would be great.I already got the time (part 1 of 4) to equal 3.3135sec but despite using the right equations etc I can't get the other three parts.
The ball was thrown horizontally. How far did it travel horizontally? Over what time? What can change the horizontal velocity?
What's its initial y-velocity? What could change the y-velocity?
Accelerationg would change it, and I tried the answer (online homework) in both negative and positive?? The initial y-velocity goes unstated.
Acceleration would change what in particular?
The ball was thrown horizontally. What does that mean for the x and y components of the initial velocity?
What equation describes the x-position with respect to time? How about the y-position?
Acceleration would change the velocity only in the y-direction. Acceleration and therefore velocity in the x-direction remain constant, with accelerationx=0 m/s.
\Deltas=vit + .5 (a)(t2)
Thanks so much!
Actually that didn't work either -___-
Didn't work for what? You'll have to be more specific. There are several parts to the problem. What are you trying to find first?
Sorry if I missed it. What's Defenestration?
