Definite integral doesn't solve with L'Hopital
Karol
Originally posted in a technical math forum, so is missing the homework template
I want to solve:
$$\int_0^\infty \frac{dx}{\left( x^2+r^2 \right)^{3/2}}=\left[ \frac{x}{r^2\sqrt{x^2+r^2}}\right]_0^\infty$$
I apply L'Hopital's to the denominator:
$$\left(r^2\sqrt{x^2+r^2}\right)'=\frac{xr^2}{\sqrt{x^2+r^2}}$$
I apply again and agin L'Hopital to this but all the time almost the same result.
Don't use L'Hopital. Divide the numerator and denominator by x.
Only the denominator:
$$\frac{r^2\sqrt{x^2+r^2}}{x}=\frac{r^4\left(x^2+r^2\right)}{x^2}=r^2\left(1+\frac{r^2}{x^2}\right)$$
And the whole integral is:
$$\left[ \frac{x}{r^2\sqrt{x^2+r^2}}\right]_0^\infty=\left[ \frac{1}{r^2\left(1+\frac{r^2}{x^2}\right)}\right]_0^\infty=\frac{1}{r^2}$$
Is that correct?
This isn't valid. You can't just go in and square something to get rid of the radical.
Is that correct?
It's the right answer but the work you show is definitely flaky. To evaluate the expression you have on the left, you need to use limits.
$$\frac{x}{r^2\sqrt{x^2 + r^2}} = \frac{x}{r^2x\sqrt{1 + (r^2/x^2)}}$$
Can you find the limit as x → ∞ of the last expression?
As x→∞:
##\frac{x}{r^2x\sqrt{1 + (r^2/x^2)}}<\frac{x}{r^2x}=\frac{1}{r^2}##
And on the other hand:
##\frac{x}{r^2x\sqrt{1 + (r^2/x^2)}}>\frac{\frac{x}{\sqrt{1 + (r^2/x^2)}}}{r^2x\sqrt{1 + (r^2/x^2)}}=\frac{x}{\left(1 + r^2/x^2\right)xr^2}=\frac{1}{\left(1 + r^2/x^2\right)r^2}\rightarrow\frac{1}{r^2}##
It's the sandwich rule, am i correct?
Karol said:
As x→∞:
For any finite value of x, x/x = 1, so the factors of x in the numerator and denominator cancel. Inside the radical, r2/x2 → 0 as x → ∞.
The work would look like this:
$$\lim_{x \to \infty}\frac{x}{x r^2 \sqrt{1 + \frac{r^2}{x^2}}} = \lim_{x \to \infty} \frac{1}{r^2\sqrt{1 + \frac{r^2}{x^2}} } = \frac{1}{r^2}$$
You shouldn't have '<'.
Apparently you're trying to get a lower bound in the work below. Using the sandwich theorem is a lot more work here than is necessary.
Thanks
