What is the deflection of an electron in a CRT with given parameters?
  • Thread starter Thread starter sami23
    Crt Deflection
sami23
An electron with an initial speed of 7x106m/s is projected along the axis midway between the deection plates of a cathode-ray tube. The uniform electric field between the plates has a magnitude of 1000 V/m and is upward. F = 1.6x10-16N and acceleration a = 1.76x1014m/s2
(a) How far below the axis has the electron moved when it reaches the end of the plates?
(b) At what angle with the axis is it moving as it leaves the plates?
(c) How far below the axis will it strike the fluorescent screen S?
An electron with an initial speed u = 7x106 m / s
The uniform electric field between the plates E = 1000 V/m
Upward force F = 1.6x10-16N
acceleration a = 1.76x1014m/s^ 2
Horizontal direction :
distance S= 6 cm =0.06 m
time taken to reach end of the plate t = S / u
= 8.57*10^-9 s
In vertical direction :
Initial velocity U = 0
Accleration a = 1.76 * 10^ 14 m / s^ 2
time t= 8.57 * 10 ^ -9 s
distance moved at the end of the plates in vertical direction y = ?
from the relation y = Ut + ( 1/ 2) at ^ 2
= 0 + 6.465* 10 ^ -3
= 6.465 * 10 ^ -3 m
(b). required angle θ = tan -1 ( y / S )
= 6.15 degrees ? I get this wrong
(c). tan θ = Y / ( S + S ' )
where S ' = 12 cm =0.12 m
from this Y = ( S+ S ' ) tan θ
= 0.01939 m
You need the angle of the velocity vector.
ehild
v = 0 + (1.508*10^6 m/s) = 1.508*10^6 m/s
u = 7*10^6 m/s
tan \varphi = v/u = 0.215
\varphi = 12.15 degrees.
Is this angle where it is moving as it leaves the plates?
Yes.
ehild
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
