Proving lim_{x->\frac{1}{10}}\frac{1}{x}=10
Metal_Zelda
Prove lim_{x->\frac{1}{10}}\frac{1}{x}=10
|f(x)-L|<epsilon, |x-a|<delta
I need to go from 1/x to x, so I applied an initial condition of delta<1/20
<br /> \frac{-1}{20}&lt;x-\frac{1}{10}&lt;\frac{1}{20}
\frac{1}{10}&lt;x&lt;\frac{3}{10}
\frac{1}{x}&lt;10<br />
Moving on to the left side of the proof,
<br /> |\frac{1}{x}-10|&lt;\epsilon
-\epsilon&lt;\frac{1}{x}-10&lt;\epsilon
This is where I am stuck. If I use the fact that 1/x<10, I end up with -epsilon<10-10<epsilon, which isn't helpful.
Metal_Zelda said:
Prove lim_{x-&gt;\frac{1}{10}}\frac{1}{x}=10
I like that so far. Now look at your original problem$$
\left| \frac 1 x - 10\right| = \frac{|1-10x|}{|x|}= \frac{|\frac 1 {10}- x|}{|\frac x{10}|}$$which you are trying to make small. Can you underestimate the denominator using your last line above?
Okay, so I took |1/x-10|<epsilon and did
\frac{1}{x}-\frac{10x}{x}&lt;\epsilon
\frac{1-10x}{x}&lt;\epsilon
\frac{-10(x-\frac{1}{10})}{x} &lt;\epsilon
-10(x-\frac{1}{10})&lt;\delta, \; \; \mbox{where} \; \; \delta=\frac{1}{20}
which leaves me with \frac{1}{200}&lt;x-\frac{1}{10}&lt;-\frac{1}{200}
,Which is impossible. epsilon/200 seems to satisfy the requirement, though.
Edit: Oops, I forgot to switch the inequality symbols. It should be
\frac{1}{200}&gt;x&gt;-\frac{1}{200}
I wasn't done editing and accidentally posted. Look at it now.
I made a few errors in my post as well. I'm going to retype everything I've done, please let me know if I've reached a solution.
|\frac{1}{x}-10|&lt;\epsilon \; \; \mbox{when} \; \; |x-\frac{1}{10}|&lt;\delta
Let δ=1/20. Then, expanding the left side, we get
-\frac{1}{20}&lt;x-\frac{1}{10}&lt;\frac{1}{20} \; \rightarrow \; \frac{1}{10}&lt;x&lt;\frac{3}{10} \; \iff \; \frac{1}{10}&lt;x \; \; \mbox {and} \; \; x&lt;\frac{3}{10}
Inverting the left side, we get
\frac{1}{x}&lt;10
Moving on to the right side,
<br /> \frac{1}{x}-\frac{10x}{x}&lt;\epsilon \; \rightarrow \; \frac{1-10x}{x}&lt;\epsilon \; \rightarrow \;<br /> \frac{-10(x-\frac{1}{10})}{x} &lt;\epsilon
We assume that
<br /> -10(x-\frac{1}{10})&lt;\delta, \; \; \mbox{where} \; \; \delta=\frac{1}{20}
<br /> \frac{1}{200}&gt;x-\frac{1}{10}&gt;-\frac{1}{200} \; \iff \; x-\frac{1}{10}&lt; \frac{1}{200}
Which implies that
\delta=min \{ \frac{1}{20},\frac{1}{200} \} \; \rightarrow \; \delta=\frac{1}{200}[\tex]<br /> <br /> I&#039;m assuming that I made a mistake on that last bit as 1/200 seems an odd bound.<br /> <br /> Edit: I&#039;m not sure why that last bit of latex isn&#039;t working. It should look like <a href="http://latex.codecogs.com/gif.latex?\delta=min&amp;space;\{&amp;space;\frac{1}{20},\frac{1}{200}&amp;space;\}&amp;space;\;&amp;space;\rightarrow&amp;space;\;&amp;space;\delta=\frac{1}{200}" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://latex.codecogs.com/gif.latex...ightarrow&amp;space;\;&amp;space;\delta=\frac{1}{200}</a>
Your ##\delta## must depend on ##\epsilon##. I think if you are careful you will find, with your original assumptions that ##\delta =\frac \epsilon {200}## will work. I suggest you work with absolute values. Think about underestimating ##\frac {|x|}{10}## in the denominator as I suggested. It's only another step or two.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
