How Do You Calculate Buoyancy and Density for Different Blocks?
  • Thread starter Thread starter JJBrian
    Buoyancy Density
The discussion focuses on calculating buoyancy and density for two blocks with specific dimensions and masses. For the first block, its volume is calculated as 0.000112 m³, yielding a density of 598.214 kg/m³, and the depth submerged in water is approximately 0.019964 m. The second block, a metal cube, displaces a volume of water equal to its own volume when submerged, which is 0.000008 m³, leading to a buoyant force of 0.0784 N. The apparent weight of the submerged metal block is discussed, emphasizing that it is reduced by the buoyant force compared to its weight in air. The conversation highlights the importance of understanding buoyancy and density calculations in different scenarios.
JJBrian
1. A block is 7 cm wide, 8 cm long, and 2 cm tall and has a mass of 67 g.
a) What is its volume?
b) What is its density?
c) Floating in water (with the 7x8 face down), how deep will the bottom be (what is x in
figure 2)?
d) How much extra weight can it support without sinking?
2. A 2 cm by 2 cm by 2 cm metal block has a mass of 80 g.
a) What volume of water does it displace when it is submerged?
b) What is the weight of the water displaced?
c) What is the apparent weight of the block when measured under water?
A=Lw.
V=Ah=Lwh.
density = m/v
Fbuoyancy = (Mass displaced water)*g
mblock*g = Fbuoyancy =mdisplaced water*g
---->density of block* volume of block = density water* Volume displaced water
----> DENSITY BLOCK*H = DENSITY WATER X
Fbouyancy = density water*Volume of block
1a)V=Ah=Lwh.
(.08m)(.07m)(.02m)
V=0.000112m^3
1b)density = m/v
.067kg/0.000112m^3 = 598.214kg/m^3
c) Density block* h = densitywater*x
(598.214kg/m^3)(.02m) =(1000kg/m^3) x
x=0.019964m
d)m displaced water = Vblock* density water
Mdw = (.000112m^3)(1000kg/m^3)
Mdw = 0.112kg Mblock = .067kg
mass block - massdw = .045kg
2a)
V=Lwh
V=(.02)(.02)(.02) = .000008m^3
Density = 10,000kg/m^3
Pbmetal*Vmetal = density water*Vdisplaced water
(10,000kg/m^3)(.000008m^3) = (1000kg/m^3)( Vdw)
Vdw = 0.00008m^3
b)F bouyancy = density water * vblock*g
=(1000kg/m^3)(.000008m^3)(9.8m/s^2)
=0.0784N
dw =(1000kg/^3)(.000008m^3) =.008kg
Fbouyancy = Mdw*g= .0784N
c) I don't know...
=0.0784N
Can someone check my work?
Question 2a-c, I am unsure of. I need some explanation or some ideas to solve 2b and 2c.
JJBrian said:
1a)V=Ah=Lwh.
(.08m)(.07m)(.02m)
V=0.000112m^3
1b)density = m/v
x=0.019964m
All good.
2a)
V=Lwh
Vdw = 0.00008m^3
Careful here. Since the metal cube is totally submerged, the volume of water displaced is just equal to the volume of the cube. Do not try to compute the volume of displaced water by setting its weight equal to the weight of the cube--it's not floating!
=0.0784N
OK.
c) I don't know...
=0.0784N
Imagine you suspended this metal cube by a string. The tension in the string is its "apparent" weight. In air, that tension just equals the weight of the cube. But when the cube is submerged in water, the apparent weight is reduced by the upward buoyant force. (Something floating would have an apparent weight of zero.)
In vacuum to be precise. It may seem as a nitpicking, but bouyancy in the air means you will be off by about 0.1% (order of magnitude, exact value depends on the density of the object). If you need high accuracy that's not a thing to forget :-p
See http://www.titrations.info/volumetric-glass-calibration for example calculation in the real lab situation (scroll down to the text on the grey background).
methods
Good point. Shame on me! :-p
LOL it is the first time that I pointed out at yor mistake, so far it was always the other way around :smile:
