Solving Density Problems: Neutron Stars Homework
  • Thread starter Thread starter drewsteriam
    Density
Neutron stars are incredibly dense, with a typical mass of 2.7 x 10^28 kg and a radius of 1.2 x 10^3 m. To find the density, the formula density = mass/volume is applied, leading to a calculation of the star's density. Additionally, if a dime were made from neutron star material, its volume of 2.0 x 10^-7 m³ would result in a weight of approximately 2.2 pounds. The discussion highlights the need for clarity on relevant equations and problem-solving approaches in physics. Overall, the density of neutron stars and the weight of a dime made from their material are key focus points.
drewsteriam
Alright, this chapter in my AP Physics class has been giving me all sorts of problems, so need tons of help. Here is the first problem:
Neutron stars consist only of neutrons and have unvelievably high densities. A typical mass and radius for a neutron star might be 2.7 x 10^28 kg and 1.2 x 10^3 m. (a) Find the density of such a star. (b) If a dime (V=2.0 x 10^-7 meters cubed) were made from this material, how much would it weigh (in pounds)?
I'm not sure what equations are relevant, but I will give it a try: P+.5p(v)^2+pgy=p+.5pgy
I don't really know any of this so I don't know where to start. Any help would be appreciated, Thanks.
Density = mass/volume
2.2 pounds = 1 kg
Thanks, that was a lot simpler than I thought it would be.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
