Derivation: Entropy of Vaporisation using Redlich-Kwong EoS
The discussion focuses on deriving the entropy of vaporization using the Redlich-Kwong equation of state (EoS). The key equation for entropy change is presented as: $$ \Delta S = R\Bigg[ \ln \frac{V_2 -b}{V_1 - b} \Bigg] + \frac{0.5a}{bT^{1.5}}\ln \Bigg[ \frac{V_2(V_1-b)}{V_1(V_2-b)} \Bigg]. $$ Participants emphasize the importance of Gibbs free energy in establishing equilibrium between phases and highlight the necessity of integrating with respect to volume for accurate results. Concerns regarding the limits of integration when applying the EoS for gases are also discussed.
  • Understanding of the Redlich-Kwong equation of state
  • Familiarity with Gibbs free energy concepts
  • Knowledge of thermodynamic principles related to entropy
  • Ability to perform integration in thermodynamic contexts
  • Study the derivation of the Redlich-Kwong equation of state
  • Learn about Gibbs free energy and its applications in phase transitions
  • Explore integration techniques in thermodynamics, particularly for variable limits
  • Investigate the limitations of the Redlich-Kwong EoS for different phases
Students and professionals in thermodynamics, chemical engineering, and physical chemistry who are working on phase equilibria and vaporization processes.
Tom Hardy
For some reason it is not letting me add the image here, here is the link to the question:
http://imgur.com/a/3DLWM
The part I'm stuck on is the last part. Basically, the question is to obtain the following equation for the entropy of vaporisation using the Redlich-Kwong equation:
P = \frac{RT}{V-b} - \frac{a}{T^{0.5}V(V+b)}
I think I should start by using the known fact that at equilibrium, the free energy of both phases must be the same. Using Gibbs free energy:
dG = -SdT + VdP \implies -S_1dT + V_1dP = -S_2dT + V_2dP
Therefore, I can write an equation for change in entropy due to vaporisation:
S_1 - S_2 = (V_1 - V_2)\frac{dP}{dT}
However when I simply differentiate the given EoS and multiply by $V_1 - V_2$ I don't get the same result. Clearly, in the answer they have integrated wrt v at some point but I just don't get why or how. Any help will be appreciated, thank you.
We can't just take the derivative of P wrt to T since P is also a function of V, unless we would assume V to be constant, which would be unusual for vaporization.
Instead we can write dU=TdS=PdV for a reversible path.
If we assume isothermal vaporization, we get ##T\Delta S=\int PdV##, from which the equation follows.
Thank you, my only concern is the limits of integration. Seemingly, the lower is limit is the liquid phase volume, but how can we use this with the EoS that is only valid for gases?
