IBY
- 106
- 0
Derive the doppler shift equation from the equation in terms of frequency to one in terms of wavelenght. Clues: frequency=c/lamda, use Taylor's expansion, velocity of source is much smaller than velocity of wave.
c-velocity of wave
v-velocity of source
f-frequency
lambda-wavelenght
Doppler shift in terms of frequency
f'=f(1+\frac{v}{c}cos \theta)
Relationship between wavelenght and frequency
\lambda=\frac{c}{f}
Taylor's expansion
\sum_{n=0}^2 \frac{f'^n(f(1+\frac{v}{c}cos \theta)}{n!}x^n
I used the wavelenght-frequency relationship equation in order to substitue for f in the doppler frequency equation to get:
\frac{c}{\lambda'}=\frac{c}{\lambda}(1+\frac{v}{c}cos \theta)
\frac{c}{\lambda'}=\frac{c}{\lambda}+\frac{c}{\lambda}\frac{v}{c}cos \theta
\frac{c}{\lambda'}=\frac{c}{\lambda}+\frac{v}{\lambda}cos \theta
\lambda'=\frac{c}{\frac{c}{\lambda}+\frac{v}{\lambda}cos \theta}
\lambda'=\lambda+\frac{\lambda c}{v cos\theta}
I used Taylor's expansion to the second degree, and I got:
\lambda'=\frac{\lambda c}{2v}x^2+{\lambda+\frac{\lambda c}{v}
I small angle approximate, so x^2=sin^2 (theta), use trig id to get sin^2 (theta)=1-cos^2 (theta)
\lambda'=\frac{\lambda c}{2v}-\frac{\lambda c}{2v}cos^2 \theta+\lambda+\frac{\lambda c}{v}
\lambda'=\frac{3\lambda c}{2v}-\frac{\lambda c}{2v}cos^2 \theta+\lambda
And now, I am dead in the water.
