- 50,491
- 26,529
In classical physics, isn't any fine-grained state a delta function in phase space (i.e., a single phase space point)?Demystifier said:It's true for the delta state, but not true for most other fine grained states.
First of all, the delta state is the physically most relevant case, since arguably, a true physical system is always in such a pure state, independent of what we know about it. Thus, the argument that the thermal state arises as a coarse graining of the true physical state in the way you imagine, is already falsified.Demystifier said:It's true for the delta state, but not true for most other fine grained states.
This is just prose. The book contains the exact same math as Tolman, so the above arguments apply here as well. A single level of coarse graining is not enough to conclude an increase of entropy to ##S_{max}##. The only thing that you can conlcude is that at all times, the entropy of the coarse grained state is higher than the entropy of the fine grained state. No relation between the entropies of coarse grained states at different times is implied.Demystifier said:Anyway, I have checked also the book by Jancel, "Foundations of Classical and Quantum Statistical Mechanics", Sec. "Discussion of the generalised H-theorem" starting at page 169. He starts with "It can be seen from the foregoing developments that this theorem is obtained without any special assumptions, except the fundamental assumption of statistical mechanics, which is necessary for the statistical description of macroscopic phenomena and which cannot contradict the reversibility of the laws of mechanics." Likewise, the section ends with: "... the evolution takes place according to the deterministic laws of mechanics, the irreversibility arising from the gross nature of our observations. Thus, it is not possible to have any kind of contradiction between the statistical conclusions of the theory and the reversible behaviour of mechanical systems." I think it contradicts your view.
Not in classical statistical physics. That's why we have phase-space distributions. Fine grained distribution is defined on a continuous phase space, while in the coarse grained distribution the phase space is divided into finite cells.PeterDonis said:In classical physics, isn't any fine-grained state a delta function in phase space (i.e., a single phase space point)?
Also in statistical physics, the fine grained distribution is a delta distribution. The idea of statistical physics is to derive macroscopic properties from the microscopic details. The microscopic theory doesn't suddenly change just because we want to compute macroscopic observables. The ontology of classical mechanics as crystal clear: Every particle has one position and one position only (similarly for momentum). This must be the starting point for every proper derivation of statistical physics.Demystifier said:Not in classical statistical physics. That's why we have phase-space distributions. Fine grained distribution is defined on a continuous phase space, while in the coarse grained distribution the phase space is divided into finite cells.
The very book you quoted agrees with me:Demystifier said:@Nullstein, is there a peer-reviewed paper, or a book, that explicitly agrees with you in saying that Gibbs H-theorem does not work for the reasons you are explaining here? If not, do you consider the possibility to write a paper by yourself?
I don't think my claims are stronger. I just agree with the author of that book that Gibbs' H-theorem can't be used to derive the statistical equilibrium distribution. He makes this clear in multiple places throughout the chapter, I only quoted a fraction of them. The author wrote the exact same things as I did. Also my post #56 is an easily understandable proof with a concrete, physically relevant example that shows that it can't work. I don't think there is room to agree to disagree, because it is not possible for someone who has internalized the arguments, to disagree. There is no vagueness in this argument, all of this is exact mathematics. Also, I am convinced that this is really standard knowledge and I'm not making any claim beyond that which is taught in a standard course on statistical physics.Demystifier said:@Nullstein I think that your claims against Gibbs H-theorem are much stronger than those quotes. In other words, I don't think that those quotes confirm those of your claims with which I disagree. But anyway, I think that at this point we can agree to disagree and conclude this discussion.
I have gone through the book in some detail now. I see where I was misunderstanding the "coarse graining" terminology as it is used in the book (I am used to seeing that term used differently): as the book uses the term, the size of the phase space cells is fixed, yes.Nullstein said:Coarse graining in Gibbs' H-theorem means projecting the fine grained state on a lattice version of phase space with fixed sized phase cells. Again, please read the book (specifically eq. (51.3)).
The only distributions that are even considered in the book with regard to the Gibbs H-theorem are distributions in which the fine grained state ##\rho## is a uniform distribution in each finite coarse-grained phase space cell (the value of ##\rho## can vary from cell to cell, but it is uniform over each individual cell). The basic argument given in the book is that if we start with an ensemble that is uniformly distributed over a single phase space cell (which is what justifies the initial condition ##\rho = P##), the time evolution of that ensemble will not be uniformly distributed over a single phase space cell (so we will have ##\rho \neq P## at the later time, which is what leads to the conclusion that the Gibbs ##H## decreases).Nullstein said:Gibbs' H-theorem really evolves every initial distribution into equilibrium.
I don't think that's true. Can you cite where in the book that the distribution is uniform in each cell?PeterDonis said:I have gone through the book in some detail now. I see where I was misunderstanding the "coarse graining" terminology as it is used in the book (I am used to seeing that term used differently): as the book uses the term, the size of the phase space cells is fixed, yes.
However, I don't see anything in the book that justifies this claim of yours:
Page 170, in the paragraph above equation 51.14:jbergman said:Can you cite where in the book that the distribution is uniform in each cell?
What specifically are you responding to here? Whatever it is, it might help to quote it.Nullstein said:You have a misunderstanding here. It's not that Gibbs' H-theorem is inapplicable.
No, that's not quite what it shows. What it shows is that ##S(t_1) > S(t_0)## if the system was not in the thermal equilibrium state (whose ##H## value corresponds to ##S_\text{max}##) at ##t_0##. If the system was in the thermal equilibrium state at ##t_0##, then we cannot conclude that ##S(t_1) > S(t_0)##.Nullstein said:Gibbs' H-theorem only shows that ##S(t_1) > S(t_0)##
In classical physics, yes. (Note, however, that this is not true in quantum physics. But here I take it that we're only discussing classical physics.)Nullstein said:The actual state of the system is always a delta state
The coarse-graining is not "artificial". It's a reflection of the fact that we don't know which particular point in phase space represents the actual microscopic state of the system. That's the whole reason for using ensembles in the first place. If we knew with infinite precision the exact point in phase space that represented the actual microscopic state of the system, we would have no need for thermodynamics or statistical mechanics at all.Nullstein said:but you have to introduce some artifical coarse graining in order to apply the theorem.
You are misunderstanding the argument. The argument is not that we apply the H-theorem to explain how ##S_\text{max}## is "reached". The argument is that the H-theorem tell us that, unless the system is in a state where the entropy is already ##S_\text{max}##, the entropy will increase with time. We don't need to know specifically how the system "reaches" ##S_\text{max}##.Nullstein said:a single application of Gibbs' H-theorem doesn't suffice to reach ##S_\text{max}##
Yes, I don't mention such trivial details for the sake of brevity.PeterDonis said:No, that's not quite what it shows. What it shows is that ##S(t_1) > S(t_0)## if the system was not in the thermal equilibrium state (whose ##H## value corresponds to ##S_\text{max}##) at ##t_0##. If the system was in the thermal equilibrium state at ##t_0##, then we cannot conclude that ##S(t_1) > S(t_0)##.
Gibbs' H-theorem is classical only, so I don't see why you bring up quantum theory.PeterDonis said:In classical physics, yes. (Note, however, that this is not true in quantum physics. But here I take it that we're only discussing classical physics.)
The laws of physics don't care about what we know or don't know. The challenge is to derive the ensemble distribution from the from the true microscopic details. If a derivation can't achieve that, it has failed (as also acknowledged in the book).PeterDonis said:The coarse-graining is not "artificial". It's a reflection of the fact that we don't know which particular point in phase space represents the actual microscopic state of the system.
Sure, but we need to derive the ensemble from the microscopic details. We can't just make up assumptions that are in contradiction to the axioms. And if we assume that the microscopic distribution isn't a delta, we are in contradiction with the axioms. Once we have derived the ensemble, we can work with that. That's the whole point.PeterDonis said:That's the whole reason for using ensembles in the first place. If we knew with infinite precision the exact point in phase space that represented the actual microscopic state of the system, we would have no need for thermodynamics or statistical mechanics at all.
No, that's not what the theorem says. Read again what is written in the book. I have also explained it multiple times already. The theorem says that ##S(t_1) > S(t_0)##. It doesn't say that ##S(t_2) > S(t_1)##. You can't concluce this without the additional assumption of an intermediate coarse graining step at ##t_1##.PeterDonis said:You are misunderstanding the argument. The argument is not that we apply the H-theorem to explain how ##S_\text{max}## is "reached". The argument is that the H-theorem tell us that, unless the system is in a state where the entropy is already ##S_\text{max}##, the entropy will increase with time.
Nobody claimed that. You need to know though that the entropy keeps increasing and the theorem doesn't imply this without intermediate coarse graining.PeterDonis said:We don't need to know specifically how the system "reaches" ##S_\text{max}##.
Nowhere is that assumed. The ensemble is not the same as the actual delta-function microscopic state, nor is it claimed to be. As I said, the ensemble is used because we don't know the actual delta-function microscopic state. If we did, we would have no need for thermodynamics or statistical mechanics at all.Nullstein said:if we assume that the microscopic distribution isn't a delta
I have, multiple times. It doesn't say what you claim it says.Nullstein said:Read again what is written in the book.
You have already said the same thing multiple times. It didn't convince me then and it doesn't convince me now.Nullstein said:Let me try to explain it one last time.
