Derivative Techniques: nx^n-1 and k^x ln k
  • Thread starter Thread starter bobsmith76
    Derivative
bobsmith76
Let's take two problems, the derivative of
2x
and
xπ
For the second one the book says that answer is
πxπ-1
Well if you can do that for the above, then why not for the first problem?
The book gives the answer to the first problem as
2x ln 2
why not x2x-1?
essentially what i need to know for finding derivatives, there are two techniques.
1. nx^n-1
2. k^x ln k
when do I use which technique?
2x
and
xπ
πxπ-1
2x ln 2
why not x2x-1?
1. nx^n-1
2. k^x ln k
Because that rule only works when the power of the x term is a constant (independent of x).
To differentiate 2x, express it as exln(2). This is of the form ekx, where k is a constant.
it makes a BIG difference whether x is "upstairs" (in the exponent), or "downstairs" (being exponentiated).
if you go back to the definition:
d(2x)/dx = limh→0 (2(x+h)-2x)/h
you can see that you're not going to get an easy way to simplify.
basically, e is the "natural base" for exponential functions, and other bases have logarithms as a "conversion factor":
2x = (eln(2))x = eln(2)x
which is of the form eax, so has derivative aeax, by the chain rule.
2x and xn are very different types of functions. The first is an exponential function, so called because the variable is in the exponent. The second is a power function, so called because the variable is in the base, which is raised to a fixed power.
There is no single differentiation rule, other than the definition, that covers both of these functions. You are misusing the power rule to conclude that d/dx(2x) = x2x-1. Each of the rules has "fine print" that says when it can be applied. Read the fine print.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
