Derivative of a Series: How to Solve for x^n/((x-a1)(x-a2)...(x-an)) in Calculus
Physics lover
if y=1+a1/(x-1) +a2x((x-a1)(x-a2)) +a3x^2/((x-a1)(x-a2)(x-a3))+....+anx^n-1/((x-a1)(x-a2)...(x-an)).
Find dy/dx.
Sorry i haven't used LaTeX this time as i will first have to learn it.
Logarithmic differentiation
I first solved the first two terms and then i solved the resulting term with the third term and so on.At last i was left with x^n/((x-a1)(x-a2)...(x-an)) .Thrn i took log on both sides and then differentiated both sides with respect to x.I got 1/y dy/dx=n/x -1/(x-a1)-1/(x-a2)...-1/(x-an).But now I was stuck.How will i get rid of that n there as it is not in the answer.
Help please.
Have you checked your formula carefully? The scheme makes it look like in the second term you should have /(x-a1), the third a2x/...
Physics lover said:
Problem Statement: if y=1+a1/(x-1) +a2x((x-a1)(x-a2)) +a3x^2/((x-a1)(x-a2)(x-a3))+...+anx^n-1/((x-a1)(x-a2)...(x-an)).
Find dy/dx.
Per @epenguin's correction and adding a missing /, and written in LaTeX, the above should probably be
##y=1+a_1/(x-a_1) +a_2x/((x-a_1)(x-a_2)) +a_3x^2/((x-a_1)(x-a_2)(x-a_3))+...+a_nx^{n-1}/((x-a_1)(x-a_2)...(x-a_n))##
It's pretty simple for the equation above.
Subscripts: a_1
Exponents: x^2 or x^{n - 1}
The braces are optional if the subscript or exponent is just a single character.
Fractions: \frac {a_2x}{(x - a_1)(x - a_2)}
The LaTeX expressions can be surrounded by pairs of # characters (inline LaTeX) or pairs of $ characters (standalone LaTeX). There's a link to our tutorial at the bottom left of the input pane.
Physics lover said:
Relevant Equations: Logarithmic differentiation
I'm not sure how log differentiation is relevant. You can't simplify the log of a sum of terms.
What do you mean by "solved the first two terms"?
... and "solved the resulting term"?
Help please.
Subscripts: a_1
Thanks for editing the post.
I meant that i first wrote 1+x/(x-a_1)=x/(x-a1) and then x/(x-a11)+a2x^2/((x-a11)(x-a2)) as x^2/((x-a1)(x-a2)) and further.
I meant that i first wrote 1+x/(x-a1)=x/(x-a1) and then x/(x-a1)+a2x^2/((x-a1)(x-a2)) as x^2/((x-a1)(x-a2)) and further.
OK, so it sounds like you're doing an induction argument. If you can show (by induction) that the original expression can be written as ##y = \frac {x^n}{(x - a_1)(x - a_2) \dots (x - a_n)}##, then you can take the log of both sides and differentiate.
I have done that i got the smae thing at last then i took log
Bu
t on taking log i am stuck with 'n'term how to get rid of it
Physics lover said:
But on taking log i am stuck with 'n'term how to get rid of it
How do you know the n term is supposed to vanish? Are you basing this on a posted solution? Do you know for a fact that the posted solution is correct?
Something to try: Let ##y = 1 + \frac {a_1}{x - a_1} + \frac{a_2x}{(x - a_1)(x - a_2)} = \frac{x^2}{(x - a_1)(x - a_2)}##
Take the derivative in the normal way, and compare this with what you get using log differentiation. You might be able to get some insight into the larger problem.
I was comparing it with the answer given in my book.The answer given is (y/x) (a1/(a1-x)+a2/(a2-x)...+an/(an-x))
Does the series terminate, or is it in fact infinite?
It terminates with the last term being xn/((x-a1)(x-a2)...(x-an))
Sorry but i can't get what you said.i differentiated that and i got (2a1a2y)/x
If I start with ##y = \frac{x^2}{(x - a_1)(x - a_2)}##, I can use log differentiation to get to ##y' = \frac y x(\frac{a_1}{a_1 - x} + \frac {a_2}{a_2 - x})##, so the textbook answer seems plausible to me.
The 'n' that you're struggling with is essential in breaking things up to get to the form in your textbook.
Take things a step further than I did, and start with ##y = \frac {x^3}{(x - a_1)(x - a_2)(x - a_3)}## (i.e., with the first four terms) to see how things are working.
If you differentiate ##y = \frac {x^2}{(x - a_1)(x - a_2)}##, an intermediate step is
##\frac {y'}y = \frac 2 x + \frac 1 {a_1 - x} + \frac 1 {a_2 - x}##. Notice that I switched the orders of the 2nd and 3rd denominators on the right.
Going from here to what I posted in #13 took me about 5 steps, but it's really just algebra manipulation.
Ok it got it from this i can take 1/x common and then write 2 as (a1-x)/(a1-x)+(a2-x)/(a2-x)
Thanks for the help.I got the solution of big one also.
