Derivative of an integral with both limits as functions of x?
Asphyxiated
Find the derivative of:
\int_{tan(x)}^{2x^{2}} \frac {1}{\sqrt{1+t^{3}}} dt
\frac{d}{dx} \int_{a}^{x} f(t) dt = f(x)
I don't have an attempt because I do not know how to handle the problem... the FTC statement in 'Relevant equations' is only for the integral from a constant to a function of x, right? Help!
You can pick a constant and write that integral as the difference of two integrals, each of which only has a single limit that is a function of x.
Recall that the integral of f from a to b equals F(b) - F(a), where F' = f. Suppose there exists a function G(x) with the property that G'(x) = 1/(1+x^3). Don't forget the chain rule.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
