Derivative of Logarithm with trig
TommG
Need to find derivative
y = θ(sin(ln θ)) + cos(ln θ)
My work
θ(cos(ln θ))(1/θ) + sin(ln θ) + (-sin(ln θ)(1/θ))
(θcos(ln θ))/θ] + sin(ln θ) + ( (- sin(ln θ))/θ)
cos(ln θ) + [θsin(ln θ) - sin(ln θ)]/ θ
answer in book is 2cos(lnθ)
My work
Your answer is correct, and the book's answer is wrong. Are you sure you copied the problem correctly?
Yeah it is correct
I propose that it was supposed to be
\begin{equation*}
y(\theta) = \theta(\sin(\ln \theta) + \cos(\ln \theta)).
\end{equation*}
TommG said:
Yeah it is correct
As Quesadilla points out, the function ##f(\theta) = \theta ( \sin(\ln \theta) + \cos(\ln \theta))## is probably what you want; its derivative agrees with the book's answer.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
