Derivative of (tanh^-1(sinh(2x)))
  • Thread starter Thread starter uzman1243
    Derivative
uzman1243
see above
Im trying to use the chain rule here but I can't even get the first step. Can you guide me?
see above
tanh^(-1)(x) is also call arctanh(x). What's the derivative of that? If you don't know you could try and look it up.
Yes I am aware of that. The derivative is:
1/(1-x^2)
But how do I use the chain rule here?
1/(1-x^2)
The chain rule says the derivative of (f(g(x)))'=f'(g(x))*g'(x). f is arctanh and g(x) is cosh(2x). So?
Another way to do this is to change y= tanh^{-1}(sinh(2x) to tanh(y)= sinh(2x).
Differentiate both sides with respect to x (so the left side will be the derivative of tanh(y) with respect to y times dy/dx) and then solve for dy/dx.
it would be:
(1/(1-x^2)) * sinh2x * 2cosh2x
Is that correct? I checked wolfram for the derivative and i got:
-4cosh(2x) / cosh(4x)-3
Im not sure how I could get my solution in that format?
Thank you so much for helping me out
uzman1243 said:
it would be:
If f is arctanh and g(x) is cosh(2x). Then just as f'(x)=1/(1-x^2), f'(g(x)) should be 1/(1-g(x)^2). NOT 1/(1-x^2). Don't worry too much about comparing with Wolfram. There are many different looking ways to write the same answer.
so is this correct:
Derivative of (tanh^-1(sinh(2x))) is
(1/1-(2sinh(2x)^2) * 2cosh(2x) ?
uzman1243 said:
so is this correct:
Ok, so the right hand factor should be g'(x)=(sinh(2x))'=2cosh(2x). That looks right. The rest should be f'(g(x))=arctanh'(g(x))=1/(1-g(x)^2)). That doesn't look right. What's wrong with it?
oh a careless mistake.
is it:
(1/1-(sinh(2x)^2) * 2cosh(2x) ?
is it:
Yes, it is. You should balance your parentheses more carefully, but I know what you mean.
