"How can I find the derivative of x?
  • Thread starter climbhi
  • Tags
    Derivative
Unfortunately, this still requires you to tabulate Ψ for all the half-integers. As for why this is... I have no idea! :)In summary, the conversation discusses the possibility of finding the derivative or antiderivative of x!, which is only defined on natural numbers. The concept of taking derivatives on discrete spaces is introduced, but it is pointed out that all of calculus is based on axioms that only the real numbers satisfy. The gamma function is then mentioned as a continuous extension of the factorial, with the property that it agrees with the factorial at integer values. The conversation then shifts to discussing the numerical values of half-integer factorials and the use of the gamma function in infinite sums and products. It is
climbhi
Is there a way to find the derivative, or antiderivative for that matter, of x!. Or is there a special function for that or something?
Mathematics news on Phys.org
well, the factorial is only defined on the natural numbers, and there is no sensible way to take a derivative of any function on the naturals. in fact, all of calculus rests on certain axioms that only the real numbers satisfy.
however, there is a function defined on the reals that agrees with the factorial at integer values. it is called the gamma function. it is integrable and derivable.
In that case you can take the discrete-space derivative.
d(x!)/dx = [(x+1)! - x!]
If you want to get formal, you can consider the domain of x values the set of all real numbers superimposed with a series of delta functions occurring at every integral step.
eNtRopY
There is a continuous extension to x! called the gamma function. Using G for gamma, it has the property that for integers, G(x+1)=x!.
(In order to display the formula for G, I need integral sign, exponent, and integral limits.)
&Gamma(n) = &int(0, &infin) xn-1 e-x dx
Hurkyl
Just wondering my calculator will give a numerical value for things such as 2.5! and 3.5! For the ! command to work on my calculator you have to use either 1,2,3... or any 1/2 value of those and strangely also -1/2. How is it getting these numbers? Is it perhaps just picking the values off the Gamma function?
yup. check 1/2! it should be √π
Well actually according to my calculator it is (√π)/2, is this actually what it should be?
umm... yeah, i guess so. oops. i guess i meant to say that Γ(1/2) = √π which implies that (1/2)! = Γ(3/2) = (1/2)Γ(1/2) = 1/2√π. OK
i m always making that mistake. all the time, i forget and say that Γ(n) = n!, when actually, it should be that Γ(n+1) = n!
So I wonder why my calculator will only give values for half integer factorals and only for one negative number (-.5) would it really have been that hard for them to program in the rest of the gammma function if they were going to include all the half integers? Is there any real common use for half integer factorals that would incline them to include this feature?
Oh also, Loren, just thinking that for a few of those infinite sums and products you were trying to work out, many of them involved factorals. Could you perhaps use this Gamma function in the place and see if you could get anything to fall out?
I don't follow this step. By Hurkyl's given definition of what the Gamma function is I don't see how you can take the 1/2 outside. Am I missing something, how does that work?
Try integration by parts.
The reason your calculator only gives results for positive integers and any half integer is because those are the only values for which an exact solution is known. Well, technically the exact solution is known for nonpositive integers; +/-&infin.
The values for the gamma function can be found from the recursive relationship:
&Gamma(1) = 1
&Gamma(1/2) = sqrt(&pi)
n &Gamma(n) = &Gamma(n+1)
Hurkyl
Γ(x+1) = x!
Γ(x) = ∫t=0..infinitytx-1e-t dt = (x-1)!
so
x! = ∫t=0..infinitytxe-t dt
so
d/dx(x!) = ∫t=0..infinityln(t)*txe-t dt
good luck evaluating that.
What is the derivative of x with respect to x?
The derivative of \( x \) with respect to \( x \) is 1. This is because the derivative represents the rate of change, and the rate of change of \( x \) with respect to itself is constant.
How is the derivative of x derived?
The derivative of \( x \) is derived based on the basic principles of calculus. According to these principles, the derivative of a linear function like \( y = x \) is the slope of the line, which is 1 in this case.
Does the derivative of x change if x is raised to the power of 1?
No, the derivative of \( x \) and \( x^1 \) is the same, as \( x^1 \) is simply \( x \). The power rule of differentiation states that the derivative of \( x^n \) is \( nx^{n-1} \), which gives 1 when \( n = 1 \).
What is the significance of the derivative being 1?
The significance of the derivative being 1 is that the function \( y = x \) has a constant rate of change. For every unit increase in \( x \), \( y \) increases by the same amount.
How does the derivative of x relate to the slope of its graph?
The derivative of \( x \), which is 1, directly represents the slope of its graph. A slope of 1 means that the graph of \( y = x \) is a straight line at a 45-degree angle to the horizontal axis.
Can the derivative of x be applied in real-world scenarios?
Yes, the derivative of \( x \) can be applied in real-world scenarios where a direct, linear relationship exists between two quantities. For instance, in physics, it can represent a constant velocity.
Is the concept of the derivative of x fundamental in calculus?
Yes, the concept of the derivative of \( x \) is fundamental in calculus. It is a basic example that illustrates the concept of differentiation, which is a core principle of calculus.
  • General Math
  • General Math
  • General Math
  • General Math
