Derivatives, and a little bit of linear approxim
CookieSalesman
I have to find the deriv
of ##f(x)=xArctan(x^{3})##
I just need an explanation of how the arctan works...
So I understand the rest, but just the deriv of arctan itself is confusing for me.
So the derivative of ##arctan(x)## just in general is ##\frac{1}{1+x^{2}}##
But if it's of ##arctan(x^{3})##
Then I'm not sure what is right
So on my test I was pretty sure that when I derived arctan, that the x^2 factor meant (x)^2, so I would have to put in ##x^3##, and then I'd get ##\frac{1}{1+x^{6}}##
(That's x to the 6th, because you'd mult the exps)
But... my test says I forgot to chain rule the ##x^{3}## that's inside of arctan(), but why did the teacher write (.3x^2) as the ##g'(x)##?But I also wrote ##\frac{1}{1+3x^{4}}##, which wasn't marked wrong as the deriv of ##arctan(x^{3})##, so.. I'm confused.
If y = tan (x), then x = arctan (y), that is, arctan is the inverse function of tan.
For d/dx [arctan (x^3)], you should make the substitution u = x^3,
then d/dx [arctan (x^3)] = d/du [arctan (u)] * du/dx, by the chain rule.
The derivative of arctan u = 1/(1+u^2) [from the formula] and I'm sure you can calculate du/dx, when u = x^3
So.. wait I'm sorry, so then what's the formula?
On your last line I'm not so clear what you mean, sorry.
The last line just repeats the formula for the derivative of the arctan, with the argument of arctan being 'u' instead of 'x'. Then, because you differentiated arctan (u) with respect to 'x', and you know the relationship between 'u' and 'x', u = x^3, the chain rule calls for you to calculate du/dx and multiply that result by the derivative of arctan (u) to obtain the derivative of arctan (x^3).
I think you need to review the chain rule. It's going to come in handy if you continue to study calculus and take up integrals.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
