Deriving a formula for calculating dB based on distance
The discussion focuses on deriving a formula for calculating decibel (dB) levels based on distance from a sound source. The key formula used is dB = dBi - 20 log10 (r2/r1), where r2 is the distance from the sound source and r1 is the reference distance. The intensity of sound diminishes with distance, following the principle that sound spreads out over the surface area of a sphere, represented by I = P/(4πr²). The correct dB level at 2.0 meters from a source emitting 60.0 dB at 1.0 meter is calculated to be 54.0 dB.
  • Understanding of decibel calculations and logarithmic functions
  • Familiarity with sound intensity and its relationship to distance
  • Knowledge of the formula I = P/(4πr²) for sound intensity
  • Basic principles of sound propagation in physics
  • Study the derivation of the formula dB = dBi - 20 log10 (r2/r1)
  • Explore the relationship between sound intensity and distance in various mediums
  • Learn about the applications of decibel levels in acoustics and audio engineering
  • Investigate the impact of environmental factors on sound propagation
Students in physics, audio engineers, sound technicians, and anyone interested in understanding sound intensity and its measurement in relation to distance from a source.
wtfbuck
Decibel level from source at 1.0 m is 60.0 dB
Find dB level at distance 2.0 m.
dB = 10 log10 (I/I0) <- this one I know but couldn't see an application.
Forgot to add that I0 is equal to 1.0 x 10^-12 W/m^2
dB = dBi - 20 log10 (r2/r1), where r2 is the farther sound source and r1 is the closer one.
I arrived at the correct answer of 54.0 dB by using the looked up formula. But I'd rather know how to derive that formula that relates the source distances myself. I tried for a while but am unable to do it. Anyone able to give me some insight on how to arrive at the second formula?
Welcome to PF!
The intensity of sound diminishes with distance from the source in the same way as light or strength of gravity - because it spreads out in space. The source has a certain power in watts. You can find out the intensity (watts per meter squared) at a distance r by realizing that the power spreads out over the surface area of a sphere with radius r:
I = P/(4πr²)
You can use this once to find the P since you know I at distance 1 meter. After you know P, use it again to find the I at distance 2 meters.
The decibel level is really just a comparison of two sounds as you see from dB1 = 10 log10 (I/I0). Put in the values of I and I0 to see what it is. It will, of course, be negative because the I is lower than I0. The sound at 2 m is so many decibels lower than the sound level at 1 m.
This is a whole other definition of dB. Some intensity has been defined as being 1 dB and the formula has been used to find that the intensity of this sound at distance 1 m is 60 dB louder than the defined value. Take the 60 dB and subtract the dB1 value you calculated earlier to get this relative db value at 2 m. Say it is 6 dB lower than the 60 dB sound; then it is 54 dB relative to the original defined value.
Appreciate the help Delphi. I can see the relationship now.
20K
  • · Replies 19 ·
9K
