Deriving an acceleration from Potential Energy
To find the x-component of acceleration for a 4 kg particle influenced by a conservative force with potential energy U(x) = 6x^2 + 2, the derivative of U with respect to x must be calculated to determine the force. The force is given by Fx = -dU/dx, which leads to Fx = -12x. At x = 1 m, the force becomes -12 N, and using Newton's second law (F = ma), the acceleration can be found by dividing the force by the mass. Thus, the x-component of acceleration at x = 1 m is -3 m/s^2. This approach highlights the importance of understanding the relationship between potential energy, force, and acceleration in conservative systems.
Goatsenator
A 4 kg particle moves along the x-axis under the influence of a conservative force. The potential energy is given by U(x) = ax^2 + b, where a = 6J/m^2 and b = 2J. What is the x-component of the acceleration of the particle when it is
at x = 1 m
deltaU = -W = -mad ?
I'm not quite sure what to do here. I thought I could let U(1) = Ufinal and U(0) = Uinitial so then 6 = -W = -Fd = -mad where d = 1 m
I don't think this works because it's a conservative force along the x-axis so acceleration in mad isn't acceleration due to gravity. I'm pretty lost on this one.
It is not a constant force, so you need to get the derivative of U with respect to x to find the x component of force:
Fx=-dU/dx.
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
