I Deriving Navier-Stokes Equation
The discussion focuses on deriving the Navier-Stokes equation, starting with the acceleration of an infinitesimal fluid element expressed in terms of velocity and its gradients. The participants explore the contributions of gravitational acceleration, pressure gradients, and tangential forces to the equation. There is a request for clarification on calculating the acceleration due to tangential forces and the relationship between the stress tensor components and the velocity gradient tensor for a viscous Newtonian fluid. The conversation highlights the necessity of including all stress changes in the force balance and emphasizes the complexity of the three-dimensional approach required for accurate derivation. The final expression for the right-hand side of the Navier-Stokes equation incorporates various terms, including viscous effects and pressure gradients.
Apashanka
Just trying to derive the Navier-Stokes equation.
(1)The velocity at any point in space of an infinitesimal fluid element is v(x,y,z,t)
(2) acceleration ##\frac{dv}{dt}=\frac{\partial v}{\partial t}+\sum_i\frac{\partial v_i}{\partial x_i}{\dot x_i}##
##a=\frac{dv}{dt}=\frac{\partial v}{\partial t}+\sum_i\frac{\partial v_i}{\partial x_i}{v_i}=\frac{\partial v}{\partial t}+(v • \nabla)v=\frac{Dv}{Dt}##
On the Rhs
(1) g acceleration due to gravity.
(2) acceleration due to pressure gradient (due to normal force on the surface)=##-\frac{\nabla p}{\rho}##
Therefore ##\frac{Dv}{Dt}=g-\frac{\nabla p}{\rho}##+acceleration due to the tangential forces on the infinitesimal fluid element
Can anyone please help me out in how to calculate the acceleration due to tangential forces on the surface??
For the cubical infinitesimal volume element having edges dx,dy,dz
##F_x=\eta \frac{dv_x}{dz}|_{x,y}dxdy##
##F_y=\eta \frac{dv_y}{dz}|_{x,y}dx dy##
##F_z=\eta \frac{dv_z}{dy}|_{x,z}dx dz##
##a_x=\frac{\eta \frac{dv_x}{dz}|_{x,y}}{\rho dz}##
##a_y=\frac{\eta \frac{dv_y}{dz}|_{x,y}}{\rho dz}##
##a_z=\frac{\eta \frac{dv_z}{dy}|_{x,z}}{\rho dy}##
##\eta## is the coefficient of viscocity
Can anyone please help me in how to proceed further to put these terms in the RHS of the navier Stokes equation??
Here is a rough diagram
What is the relationship between the 6 components of the stress tensor and the components of the velocity gradient tensor for a viscous Newtonian fluid?
In your differential force balance equation, you omitted the term representing the divergence of the viscous stress tensor. Why?
The stress tensor components are ##\sigma_{ij}=\frac{1}{2}(\frac{\partial v^i}{\partial x^j}+\frac{\partial v^j}{\partial x^i})## and from Newton's law of viscocity the shear stress ##\tau=\eta \frac{\partial v}{\partial x}## that's what I have used...
But what will be the actual result and how it is coming will you please suggest...is my approach wrong??
I want to just do it with a very simplectic approach...
This equation ##\tau=\eta \frac{\partial v}{\partial x}## is the one dimensional version of this equation ##\sigma_{ij}=\frac{\eta}{2}(\frac{\partial v^i}{\partial x^j}+\frac{\partial v^j}{\partial x^i})##. You need to use the 3D version in deriving the NS equation.
You can't do it with the simplistic approach because it is 3D. Also, in your approach, you omitted the changes in the stresses from one side of the cube to the other. The missing terms in your force balance are, for the x component, $$\frac{\partial \sigma_{xx}}{\partial x}+\frac{\partial \sigma_{xy}}{\partial y}+\frac{\partial \sigma_{xz}}{\partial z}$$
Likes Apashanka and BvU
Okk using ##\sigma_{ij}=\frac{\mu}{2}(\partial_j v^i+\partial_i v^j)## the Rhs comes as ##\frac{\mu}{2\rho}(\nabla^2 v)+\frac{1}{2\rho}(\nabla(\nabla • v))-\frac{\nabla p}{\rho}+g=\frac{Dv}{Dt}##
Likes Chestermiller
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
