Design an experiment to determine which reactant is the limiting reactant
  • Thread starter Thread starter extraordinarygirl
    Design Experiment
To determine the limiting reactant between magnesium and hydrochloric acid (HCl), the experiment involves placing magnesium in a beaker containing HCl and water. If all the magnesium dissolves, it indicates that magnesium is the limiting reactant; if some remains, HCl is the limiting reactant. Participants suggest writing out the chemical equation to predict products and consider indirect measurements for better accuracy. The discussion also touches on the importance of the reaction's completion over time and hints at the implications of reaction rates. Understanding these factors is crucial for accurately identifying the limiting reactant.
extraordinarygirl
You have a piece of Mg of an unknown mass, and a beaker of water in which is dissolved an unknown amount of HCl. Design an experiment to determine which reactant is the limiting reactant.
I'm not too sure how to get started with this problem. I was thinking you could place the magnesium into the beaker of H20 and HCl and see if the magnesium dissolves at all. If all of it dissolves than the Magnesium would be the limiting reactant... but if not all of it dissolved HCl would be the limiting reactant
- Can anyone tell me if I am on the right track?:smile:
Can anyone give me an idea?:confused:
Just wondering, what kind of products do you expect to result? What are some other clues that would indicate a reaction is taking place?
Sounds like you thought this through.. I go along with your approach..
Write out the chemical equation and see what the products will be. I have a feeling that an indirect measurement will be of better use... but I'm not sure.
That's perfectly logical and all you would need to do, assuming of course the reaction goes to completion (which it will over time).
There is an implication here in Cesium's comment about rate of reaction. Do you know what it is? (query is for ExGrl)
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
