Shay10825 said:
PS - I'm a she not a he lol. Shay10825-Shayla
Gees I'm sorry. The 10825 sounded masculine to me.
I got goggles, a .5 W, 10 ohm resistor, and heat sink paste today
Great job! You also have some money and access to a metal shop. I think a volt-ohm-amp meter is not only needed here, it is a great investment. I would also check with Radio Shack if you have one near.
The soldering iron is a little tougher. This is your call but I would save the budget and borrow one if at all possible. The amount of soldering needed should be very limited.
Why don't you put on your goggles and connect your resistor to
one battery? See how long it takes to get hot. How hot does it get? When you get your volt meter, learn how to measure the voltage, current, and resistance in the circuit. Try to secure the resistor to a small piece of metal. how does this affect the heating? Also, don't forget to look up that RC color code. It is shown on the back of the resistor pack, most likely. If not, Google it.
As for the resistance wire, the nice thing about resistors is that we don't need much length. I never looked at the numbers for the nichrome wire but we can string resistors together in order to spread the heat out more. This also eliminates [mostly] insulation problems.
For example, if we use two, 1/2 watt, 10 ohm resistors connected in
parallel, we can safely [without burning up the resistors] produce 1 watt of power across a total of 5 ohms. If we use two, 1/2 watt, 5 ohm resistors connected in
series, we can produce 1 watt of power over 10 ohms. So we have a lot of flexibility by playing with the configuration. We could use four or five resistors if needed.
Still need that battery current number. We will be back.
