How to Create a 90-Degree Turning Infield Carrier for Motorcycles
  • Thread starter Thread starter roronoazorro
    Carrier Design
The discussion focuses on creating a 90-degree turning mechanism for an infield carrier attached to a motorcycle, designed to tip off using gravity without requiring the user to dismount. The project involves connecting two cylinder shafts, with a load capacity of around 300 kg filled with palm oil. Suggestions include using a Hooke coupling and offset drive to allow the connection to follow the carrier's movement and achieve the desired twisting motion. Participants seek clarification on the specific application and mechanics involved in the design. The goal is to ensure the connection functions effectively within the constraints of the project.
roronoazorro
how to joint two cylinder shaft which can make it turn 90degree
anyone can give their opinion for me? :D
Can you give more information of what you're trying to do? What is the application? Is it twisting 90 degrees or bending 90 degrees or something else altogether?
the project is infield carrier.. this carrier connect to motorcyle..this carrier need to tip off by using gravity that make the user don't need to down from motorcycle. this connection play a role to make it success.. sorry my english not so good..
the project is infield carrier.. this carrier connect to motorcyle..this carrier need to tip off by using gravity that make the user don't need to down from motorcycle. this connection play a role to make it success.. this carrier is fill with palm oil. the load inside carrier around 300kg. sorry my english not so good.. so i thought i want to join this conection by using hooke coupling and offset drive.. its better?? because i want to make this conection can follow the rhythm of carrier and can twist around 90degree.. anyone can give suggestion??
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
